AndrewOW Posted January 14, 2011 Share Posted January 14, 2011 Yes, I would've thought that as well, but I bet it was mentioned at the time. The gits. Such a shame for him though. He's cleaned it to death! Quote Link to comment Share on other sites More sharing options...
Matt H Posted January 14, 2011 Share Posted January 14, 2011 but I bet it was mentioned at the time What do you mean? That they told Rob that they were going to do a bodge job to get the colour match right and whether he was ok with that? Quote Link to comment Share on other sites More sharing options...
AndrewOW Posted January 14, 2011 Share Posted January 14, 2011 What do you mean? That they told Rob that they were going to do a bodge job to get the colour match right and whether he was ok with that? No, I mean that they probably mentioned something along the lines of we can only guarantee the work for 4-6 months, etc. I had that mentioned to me when I had some work done on an Astra GTE I had once. They knew the rust would come through again, but not at least for a few months, but was outside of the time mentioned. I just hope it wasn't the same for him. Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted January 14, 2011 Share Posted January 14, 2011 we dont offer no warranty ect but if there is any problem we just do it anyway, as its our name stamped on the car at the end of the day and we rely on word of mouth alot. not all bodyshops are like us and it makes me boil. Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted January 14, 2011 Share Posted January 14, 2011 No, I mean that they probably mentioned something along the lines of we can only guarantee the work for 4-6 months, etc. I had that mentioned to me when I had some work done on an Astra GTE I had once. They knew the rust would come through again, but not at least for a few months, but was outside of the time mentioned. I just hope it wasn't the same for him. if a bodyshop can stop rust they would be millionaires, we say the same when rust is involved but its not the case here Quote Link to comment Share on other sites More sharing options...
AndrewOW Posted January 14, 2011 Share Posted January 14, 2011 if a bodyshop can stop rust they would be millionaires, we say the same when rust is involved but its not the case here. Yes, this lot are just incompetent by the looks of it. I was told they welded new pieces of metal into the rusted areas, prepped and protected it before repainting. You know what? They lied! They just filled and sprayed over the top. Once the top coat's on, it looks great - for a while. Quote Link to comment Share on other sites More sharing options...
Matt H Posted January 14, 2011 Share Posted January 14, 2011 No, I mean that they probably mentioned something along the lines of we can only guarantee the work for 4-6 months, etc Yes, they definately would have told him the length of gaurantee, but that should only be applicable on work that is done correctly. If it's been fudged badly and it's provable, then Rob should be in a good position to get something sorted. we dont offer no warranty So you do offer a warranty then Quote Link to comment Share on other sites More sharing options...
Matt H Posted January 14, 2011 Share Posted January 14, 2011 if a bodyshop can stop rust they would be millionaires, we say the same when rust is involved but its not the case here Surely if the bodyshop removes the area of rust and replaces the holes then that would be rust issue resolved? I would not expect it to come back. Quote Link to comment Share on other sites More sharing options...
Matt H Posted January 14, 2011 Share Posted January 14, 2011 I was told they welded new pieces of metal into the rusted areas, prepped and protected it before repainting. You know what? They lied! They just filled and sprayed over the top. Once the top coat's on, it looks great - for a while. Well that's a prime example of mal-practice. Quote Link to comment Share on other sites More sharing options...
Abz Posted January 14, 2011 Share Posted January 14, 2011 Surely if the bodyshop removes the area of rust and replaces the holes then that would be rust issue resolved? I would not expect it to come back. Rust is rust, it will come back if an area is fragile to rust. Example in an FTO I had, the inners side (either side when you lift up the bonnet) had rust issue and dispute welding in new metal plates rust would come back as that area was prone to rust. I believe in this case it is due to the drainage of the water, and as you know water, moisture, metal & salt don't really go well together. Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted January 14, 2011 Share Posted January 14, 2011 Surely if the bodyshop removes the area of rust and replaces the holes then that would be rust issue resolved? I would not expect it to come back. the only way to eliminate rust would be to replace the panel, if you cut the rust out and weld in plates there is still a chance of rust re appearing after many months or years.... sometimes never but you have to warn the customer of the risks. Quote Link to comment Share on other sites More sharing options...
AndrewOW Posted January 14, 2011 Share Posted January 14, 2011 So you do offer a warranty then Yes, he doesn't. Quote Link to comment Share on other sites More sharing options...
Matt H Posted January 14, 2011 Share Posted January 14, 2011 the only way to eliminate rust would be to replace the panel, if you cut the rust out and weld in plates there is still a chance of rust re appearing after many months or years.... sometimes never but you have to warn the customer of the risks. If I had an area of rust - say 2 inches in diameter - and a bodyshop cut out a large area around it and they welded in a new panel, re-sprayed it to seal it in then unless water gets through the paint (say a crack) then that rust shouldn't come back. Quote Link to comment Share on other sites More sharing options...
hemmjonny Posted January 14, 2011 Share Posted January 14, 2011 I know a really really good body shop in Camelford if trays any help to you? Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted January 14, 2011 Share Posted January 14, 2011 If I had an area of rust - say 2 inches in diameter - and a bodyshop cut out a large area around it and they welded in a new panel, re-sprayed it to seal it in then unless water gets through the paint (say a crack) then that rust shouldn't come back. but it might come back elsewhere on the panel or around the repair, as i have said if anyone can get rid of rust for good they would be millionaires. Quote Link to comment Share on other sites More sharing options...
Matt H Posted January 14, 2011 Share Posted January 14, 2011 but it might come back elsewhere on the panel or around the repair, as i have said if anyone can get rid of rust for good they would be millionaires. Fair do's I guess the only true way to avoid rust completely is to use a non-reactive material. Brass cars for the win! Quote Link to comment Share on other sites More sharing options...
Blackie Posted January 14, 2011 Share Posted January 14, 2011 Sh1+ mate thats bad, Quote Link to comment Share on other sites More sharing options...
AndrewOW Posted January 14, 2011 Share Posted January 14, 2011 Fair do's I guess the only true way to avoid rust completely is to use a non-reactive material. Brass cars for the win! Or aluminium, or carbon fibre. Quote Link to comment Share on other sites More sharing options...
Matt H Posted January 14, 2011 Share Posted January 14, 2011 Or aluminium It sort of does, but it's surface layer protects the rest of it - see passivation! Quote Link to comment Share on other sites More sharing options...
TopgunTT Posted January 14, 2011 Share Posted January 14, 2011 That looks bad mate, Hope you manage to get it sorted. Quote Link to comment Share on other sites More sharing options...
marbleapple Posted January 14, 2011 Share Posted January 14, 2011 I hate body shops. Never known one that actually does a good job. Get them to fix it. If they won't/don't then sue them. Quote Link to comment Share on other sites More sharing options...
DodgyRog Posted January 14, 2011 Author Share Posted January 14, 2011 Anybody had any dealings with these people on Ebay, http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=260722066970&ssPageName=STRK:MEWAX:IT if I have to respray, might as well go the whole hog, not sure where the moneys going to come from, but might as well start planing. Got a Trd front sat in the consevatory as well, waiting for fitting, prep and paint Quote Link to comment Share on other sites More sharing options...
Josh Posted January 14, 2011 Share Posted January 14, 2011 Not good to hear . I'd say get pictures and proof that they carried out the work and did a very poor job then go through the legal route! Quote Link to comment Share on other sites More sharing options...
Attero Posted January 21, 2011 Share Posted January 21, 2011 This might be random but it's relevant... I had a dream about repsraying your sideskirt last night and we were good buddies. Quote Link to comment Share on other sites More sharing options...
DamanC Posted January 21, 2011 Share Posted January 21, 2011 Shocking Quote Link to comment Share on other sites More sharing options...
