Guest Intruder Posted January 14, 2011 Share Posted January 14, 2011 Hi MAtes ! I intrudoced myself in the newbe area! I bought myself a MKIV N/A auto Supra and want to delimit her. I bought via ebay a delimiter from this company and they have online the fitting instructions, but when I read the HOW TO topic, it seems that this thing is a bad one ( the installation seems tooooo easy...????) can anyone help???? http://www.svaspeedos.co.uk/pdfs/toyota/SUPRA.pdf thank you so much for maybe preventing me of trouble ben Quote Link to comment Share on other sites More sharing options...
supra steveo Posted January 14, 2011 Share Posted January 14, 2011 doh the info is helpful have a look for a thor speedo convertor and TSD ( top speed de-limiter) i fitted one middle of last year and it was very straight forward and the instructions that came with it were very clear Quote Link to comment Share on other sites More sharing options...
Homer Posted January 14, 2011 Share Posted January 14, 2011 Are you looking to only delimit or do a delimit and speedo conversion to mph? The unit you have bought is a generic convertor which will screw up the PAS and several other things if installed as directed. However, it can be installed at the dial loom to correct the kph signal to the speedo and even to delimit it (well to 186mph at least!) via a spur to the ECU, but I personally wouldn't bother as it'll still cause the PAS over-correction issue. As Steve mentioned above something like the Thor unit which has both a clamped ECU signal for the de-limit and a corrected PAS signal is essential. There are other units available via ebay which do both but they are quite rare to find. Quote Link to comment Share on other sites More sharing options...
