Guest Eduardo Posted January 14, 2011 Share Posted January 14, 2011 Help [sHOCK][/sHOCK] I have a Supra 1993 nonTurbo that has been diagnosed with an head gasket failure. So far the engine is running fine, just drinking coolant. I'm in Margate, Kent. Any ideas? thanks Quote Link to comment Share on other sites More sharing options...
Dnk Posted January 14, 2011 Share Posted January 14, 2011 (edited) Take it to a decent garage and get the fault verified, if it is the head gasket you need to have the head checked that its not warped in case its overheated. If the heads not warped fit new gasket job done. If the heads warped by any decent amount you'll need a new one, it could be cheaper to just fit a complete engine as their apparently quite cheap. Edited January 14, 2011 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted January 14, 2011 Share Posted January 14, 2011 I would suggest the best idea is to get it repaired. HTH Quote Link to comment Share on other sites More sharing options...
Guest Eduardo Posted January 14, 2011 Share Posted January 14, 2011 The head gasket leak was verified by Toyota in Canterbury through a sniffer test. where can I get a new engine? I'm in Kent. What is quite cheap? Is there anyone out there (in the forum) that has enough mechanics knowledge to perform the repair (the cambelt is also due in 5000miles) and wants to buy the car? Anybody with experience in running the car drinking coolant? thanks Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted January 14, 2011 Share Posted January 14, 2011 A head gasket is very rare on a JZ engine but I suppose if Toyota diagnosed it its not some back street clown. Why dont you just get it fixed? Any competent garage can do it. Sure theres no leaks anywhere? Quote Link to comment Share on other sites More sharing options...
JohnHandy Posted January 14, 2011 Share Posted January 14, 2011 The head gasket leak was verified by Toyota in Canterbury through a sniffer test. where can I get a new engine? I'm in Kent. What is quite cheap? Is there anyone out there (in the forum) that has enough mechanics knowledge to perform the repair (the cambelt is also due in 5000miles) and wants to buy the car? Anybody with experience in running the car drinking coolant? thanks If it has messed the engine up keron will have mine in about a week you could drive up and get him to throw it in yours for you. He's a good bloke and will look after you mate. It's got 85 on the clock and some of that will be km so good low milage it's been great for me but it's now time for me to go TT Quote Link to comment Share on other sites More sharing options...
Supra Gaz Posted January 14, 2011 Share Posted January 14, 2011 You can pick up a 2jz ge for a couple of hundred quid. It would probably work out cheaper and better just to get the headgasket done though. Quote Link to comment Share on other sites More sharing options...
Geo Posted January 14, 2011 Share Posted January 14, 2011 im sure RyanG was selling a 2jz-ge for £250 Quote Link to comment Share on other sites More sharing options...
Ryan.G Posted January 15, 2011 Share Posted January 15, 2011 Yup i have one for £250 with everything needed to drop straight in your car. Could do it for £300 Delivered to your door on pallet Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 16, 2011 Share Posted January 16, 2011 If the head has warped it's almost certainly scrap. has it been overheated AT ALL??? If so find another engine as the cam bearings will be no longer in line, ut more like a banana. That is not economically repairable. You can skim the head to block face but the bearings will remain out of line. Quote Link to comment Share on other sites More sharing options...
