neo2810 Posted January 17, 2011 Share Posted January 17, 2011 If you take the old bulb out of the holder (it is possible - i've done it) you can get some bulbs of an appropriate size from Maplin. They have long tails so you just poke them through the holes in the plastic holder and then wrap the tails around a couple of times. If you try it I'm sure you'll figure it out! You can't just do that unless you get bulbs with a built in resistor. The speedo unit has 3x T10 bulbs and 1x T5 (Superflux), which are readily available on eBay. The ignition takes 1x T5. The AC control unit is a different story and you either need toyota replacements or go blue/red by following hecklers LED conversion guide Link to comment Share on other sites More sharing options...
supra steveo Posted January 17, 2011 Share Posted January 17, 2011 Im after the ones behind the clocks ie speedo, tacho etc Thanks you need the bulb holders too ? Link to comment Share on other sites More sharing options...
Josh Posted January 17, 2011 Author Share Posted January 17, 2011 Received my bulbs today. Thanks a lot, Steve. I owe you one Link to comment Share on other sites More sharing options...
straightsix Posted January 17, 2011 Share Posted January 17, 2011 You can't just do that unless you get bulbs with a built in resistor. The speedo unit has 3x T10 bulbs and 1x T5 (Superflux), which are readily available on eBay. The ignition takes 1x T5. The AC control unit is a different story and you either need toyota replacements or go blue/red by following hecklers LED conversion guide My post didn't show the quote - I was answering Supranature's post at the top of the page: 'Steve, all of mine need replacing bud, not the LED ones, just the ones that show airflow direction, I'm guessing about 12. Actually, this is probably a loose connection inside, as I find it highly unlikely that they would all go either simultaneously or at random. How many have you got, I would like to pay for them should they be needed. Sorry for thread hijack Josh!' Link to comment Share on other sites More sharing options...
Ryan.G Posted January 18, 2011 Share Posted January 18, 2011 you need the bulb holders too ? Are the old ones re-usable? After white Bulbs or LEDS Link to comment Share on other sites More sharing options...
fuldhat Posted January 18, 2011 Share Posted January 18, 2011 The link to the instruction dont work... Link to comment Share on other sites More sharing options...
supra steveo Posted January 18, 2011 Share Posted January 18, 2011 (edited) My post didn't show the quote - I was answering Supranature's post at the top of the page: 'Steve, all of mine need replacing bud, not the LED ones, just the ones that show airflow direction, I'm guessing about 12. Actually, this is probably a loose connection inside, as I find it highly unlikely that they would all go either simultaneously or at random. How many have you got, I would like to pay for them should they be needed. Sorry for thread hijack Josh!' send a picture, and no need to say sorry for the Hi-Jack josh is sorted so its all fair game Are the old ones re-usable? After white Bulbs or LEDS yes you could use the bulb holders behind the dash again basically they are just sidelights with green dildo's on The link to the instruction dont work... http://www.internetwork.org.uk/led_guide/led.htm use this link to sort the bulbs Edited January 18, 2011 by supra steveo (see edit history) Link to comment Share on other sites More sharing options...
JS2004 Posted February 7, 2011 Share Posted February 7, 2011 Sorting out my dash lights also - is it possible to replace the normal small sidelight bulbs, with the long prongs and green sheath thing with LEDs? The bulbs on mine blew, but not the orange LEDs, so I just want to swap out the dead bulbs for something better. Im not sure if theres a certain voltage.. ampage or whatever that should be used (electrical newb). Link to comment Share on other sites More sharing options...
neo2810 Posted February 7, 2011 Share Posted February 7, 2011 Sorting out my dash lights also - is it possible to replace the normal small sidelight bulbs, with the long prongs and green sheath thing with LEDs? The bulbs on mine blew, but not the orange LEDs, so I just want to swap out the dead bulbs for something better. Im not sure if theres a certain voltage.. ampage or whatever that should be used (electrical newb). http://www.internetwork.org.uk/led_guide/led.htm Link to comment Share on other sites More sharing options...
JS2004 Posted February 7, 2011 Share Posted February 7, 2011 (edited) Nm, dont feel up to doing the whole converstion so ill go with stock replacements from Mr T. Id probably do it wrong and kill the unit. Edited February 7, 2011 by JS2004 (see edit history) Link to comment Share on other sites More sharing options...
viper Posted December 12, 2011 Share Posted December 12, 2011 old thread i know but is there someone about who does these conversions to save me the hassel? Link to comment Share on other sites More sharing options...
kjgreen3 Posted December 12, 2011 Share Posted December 12, 2011 PM Heckler He's a Forum approved hobbyist and supra electronics Guru. He can build you a bespoke unit. Here is his thread. Click: http://www.mkivsupra.net/vbb/showthread.php?231724-Face-Lift-Dash-PCB-s-in-Blue&highlight=Heckler Hope this helps. Link to comment Share on other sites More sharing options...
Jellybean Posted January 30, 2012 Share Posted January 30, 2012 I got EbaY led'S for the Dials, they lasted two weeks. I need to get the MOT and want to just put in Osrams Will these do? OSRAM Cool Blue Intense W5W ; How many do I need for the Dash Dial Cluster (REV, Speedo, Gas & Temp) http://www.powerbulbs.com/product/cool-blue-intense-w5w-twin I want to get Heckler to trick it out with LED's eventually but I just dont have the Cash at the moment, new tyres , service etc needed too Something cheap and cheeful to get me through the MOT Link to comment Share on other sites More sharing options...
