TonytotheB Posted January 13, 2011 Share Posted January 13, 2011 Hi chaps Has anyone cleaned a brake disk before? Mine have got gunk on them and I want to clear this as the reason for my slight grind. I fear the lack of cleaning and bad roads have lead to this problem. Also, the fact I live in the greenest and most wet place on Earth (Yorkshire) doesn't help Spit and elbow grease? Thanks Teebs Quote Link to comment Share on other sites More sharing options...
neo2810 Posted January 13, 2011 Share Posted January 13, 2011 Buy a can of "brake degreaser" from halfords and blast away. It's simple enough... Quote Link to comment Share on other sites More sharing options...
Graham S Posted January 13, 2011 Share Posted January 13, 2011 WD-40 mate, that'll do the job well! On a serious note, try a motor factors for something called brake cleaner! (I'm not taking the hit and miss either!) Quote Link to comment Share on other sites More sharing options...
TTRickeh Posted January 13, 2011 Share Posted January 13, 2011 I would've thought a spirited drive would clear all the gunk off them pretty sharpish Quote Link to comment Share on other sites More sharing options...
TonytotheB Posted January 13, 2011 Author Share Posted January 13, 2011 wd-40 ftw! Thanks. Is it best to remove the caliper unity bit before cleaning the disc? If so, I need new pins! I would've thought a spirited drive would clear all the gunk off them pretty sharpish I would but I fear they might not stop me Quote Link to comment Share on other sites More sharing options...
Guigsy Posted January 13, 2011 Share Posted January 13, 2011 Just drive arround somewhere quiet with the brakes on for a bit Quote Link to comment Share on other sites More sharing options...
Josh Posted January 13, 2011 Share Posted January 13, 2011 Just drive arround somewhere quiet with the brakes on for a bit +1 Quote Link to comment Share on other sites More sharing options...
Graham S Posted January 13, 2011 Share Posted January 13, 2011 Driving around with grease on a disc or whatever will only in turn contaminate the pads! Personally i'd go buy a can of brake cleaner aeroso,l spray the disc and turn it at the same time, then wipe it with a bit of clean rag/tissue or whatever you use! Job done, then take it for a drive! Quote Link to comment Share on other sites More sharing options...
Terminator Posted January 14, 2011 Share Posted January 14, 2011 If the gunk on them contains any grease or oil, do not clean the the disc with the pads in the calliper, as the brake cleaner will just help any grease to soak into the pads. Quote Link to comment Share on other sites More sharing options...
