Rob_Mitchell Posted January 13, 2011 Share Posted January 13, 2011 (edited) have a little question is it right to have a very slight movement side to side on a rebuilt engine from the forged pistons? Edited January 13, 2011 by Rob_Mitchell (see edit history) Quote Link to comment Share on other sites More sharing options...
davej705 Posted January 13, 2011 Share Posted January 13, 2011 I asked Lee p about this and he said it was totally normal and to be expected Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted January 13, 2011 Author Share Posted January 13, 2011 I asked Lee p about this and he said it was totally normal and to be expected just double ckecking mate, got me worried now. Quote Link to comment Share on other sites More sharing options...
davej705 Posted January 13, 2011 Share Posted January 13, 2011 When I took the head off I checked and concerned me so I phoned Lee.he explained that when the piston warms up it expands slightly and that's how it should be. Not sure but if I had to guess I would say maybe this is what causes piston slap in forged motors on start up. Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted January 13, 2011 Author Share Posted January 13, 2011 When I took the head off I checked and concerned me so I phoned Lee.he explained that when the piston warms up it expands slightly and that's how it should be. Not sure but if I had to guess I would say maybe this is what causes piston slap in forged motors on start up. sounds like it makes sense mate, cheers dave. Quote Link to comment Share on other sites More sharing options...
BOB B Posted January 13, 2011 Share Posted January 13, 2011 Yes I had my engine rebuilt by AFR using forged pistons and John explained that they are slightly smaller when cold and that they rattle around a bit on cold start and its good practice to let them warm up first. you can really hear the difference on a cold start to when they have warmed up nicely. Quote Link to comment Share on other sites More sharing options...
davej705 Posted January 13, 2011 Share Posted January 13, 2011 (edited) Give Lee a call if your still concerned fella Also will be with you tomorrow,just got to refit the gearbox.glad I never took my van to Vw to fix,would have cost a small fortune in labour Edited January 13, 2011 by davej705 (see edit history) Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted January 13, 2011 Author Share Posted January 13, 2011 Give Lee a call if your still concerned fella cant keep bothering him its not fair and he's prob sick of me lol. im sure its fine and perfectly normal as the heat up makes perfect sense. Quote Link to comment Share on other sites More sharing options...
davej705 Posted January 13, 2011 Share Posted January 13, 2011 cant keep bothering him its not fair and he's prob sick of me lol. im sure its fine and perfectly normal as the heat up makes perfect sense. Lol I've only called him a couple of times but he gets quite a few pm's from me! Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted January 13, 2011 Author Share Posted January 13, 2011 Lol I've only called him a couple of times but he gets quite a few pm's from me! i ring him all the time asking about stuff lol but i will be keeping him busy soon. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 13, 2011 Share Posted January 13, 2011 Measure the pistons (in the correct place and in the correct way) and the bores. Subtract one from t'other and check against the piston spec sheet if you are that worried. Otherwise trust the engine builder If you are going to check every thing he does you might as well do it yourself! Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted January 13, 2011 Author Share Posted January 13, 2011 Measure the pistons (in the correct place and in the correct way) and the bores. Subtract one from t'other and check against the piston spec sheet if you are that worried. Otherwise trust the engine builder If you are going to check every thing he does you might as well do it yourself! the engine was built 10k miles ago chris, i think all is ok but just thought i would ask as i have never owned or worked on a rebuilt/balanced engine before Quote Link to comment Share on other sites More sharing options...
