Guest Terry S Posted June 22, 2005 Share Posted June 22, 2005 OK you have a fair point, but I have never had an issue with either SRF or RBF and considering the difference in cost there seems a logical choice. Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted June 22, 2005 Share Posted June 22, 2005 Thought you may find this interesting: ARRANGED BY DRY BOILING POINT: DRY:401F -- WET:284F --- DOT3 MINIMUM (GLYCOL BASE) DRY:446F -- WET:311F --- DOT4 MINIMUM (GLYCOL BASE) DRY:500F -- WET:356F --- DOT5 MINIMUM (SILICONE BASE) DRY:500F -- WET:356F --- DOT5.1 MINIMUM (GLYCOL BASE) DRY:527F -- WET:302F --- AP RACING 551 ($12.95/0.5L OR 16.9 OZ) DRY:527F -- WET:347F --- VALVOLINE SYNPOWER DOT3 & DOT4 DRY:536F -- WET:392F --- ATE SUPERBLUE/TYP200 ($9.95/1L) DRY:550F -- WET:284F --- FORD HEAVY DUTY DOT 3 ($4/12 OZ) DRY:570F -- WET:284F --- WILWOOD 570 ($5.65/12 OZ) DRY:570F -- WET:284F --- PERFORMANCE Friction Z rated ($6.27/16 OZ) DRY:590F -- WET:410F --- AP RACING 600 ($16.95/0.5L OR 16.9 OZ) DRY:590F -- WET:518F --- CASTROL SRF ($69.00/1L 0R 33.8 OZ) DRY:593F -- WET:420F --- MOTUL RBF600 ($12.95/0.5L OR 16.9 OZ) DRY:601F -- WET:399F --- BREMBO LCF 600 PLUS ($26.75/0.5L OR 16.9 OZ) DRY:608F -- WET:390F --- AP RACING 660 ($-/0.5L OR 16.9 OZ) DRY:610F -- WET:421F --- NEO SYNTHETICS SUPER DOT 610 ($11.95/12 OZ) DRY:610F -- WET:421F --- PROSPEED GS610 ($39.95/16 OZ) DRY:626F -- WET:417F --- WILWOOD EXP 600 ($16.95/0.5L 16.9 OZ) ARRANGED BY WET BOILING POINT: DRY:401F -- WET:284F --- DOT3 MINIMUM DRY:570F -- WET:284F --- WILWOOD 570 DRY:570F -- WET:284F --- PERFORMANCE Friction Z rated DRY:550F -- WET:284F --- FORD HEAVY DUTY DOT 3 DRY:527F -- WET:302F --- AP RACING 551 DRY:446F -- WET:311F --- DOT4 MINIMUM DRY:527F -- WET:347F --- VALVOLINE SYNPOWER DOT3 & DOT4 DRY:500F -- WET:356F --- DOT5.1 MINIMUM (GLYCOL BASE) DRY:500F -- WET:356F --- DOT5 MINIMUM (SILICONE BASE) DRY:608F -- WET:390F --- AP RACING 660 ($-/0.5L OR 16.9 OZ) DRY:536F -- WET:392F --- ATE SUPERBLUE/TYP200 DRY:601F -- WET:399F --- BREMBO LCF 600 PLUS DRY:590F -- WET:410F --- AP RACING 600 DRY:626F -- WET:417F --- WILWOOD EXP 600 DRY:593F -- WET:420F --- MOTUL RBF600 DRY:610F -- WET:421F --- NEO SYNTHETICS SUPER DOT 610 DRY:610F -- WET:421F --- PROSPEED GS610 DRY:590F -- WET:518F --- CASTROL SRF Quote Link to comment Share on other sites More sharing options...
oilman Posted June 22, 2005 Share Posted June 22, 2005 I would go with RBF, it's sensibly priced and damned good! http://www.opieoils.co.uk/TechSpecs/Mobil%20and%20Motul/RBF_600_factory_line_8069.pdf Cheers Simon Quote Link to comment Share on other sites More sharing options...
