w41k3r Posted January 12, 2011 Share Posted January 12, 2011 is there any real difference in these two wideband setups im looking to purchase one but thought i`d ask the wise, is there really any advantage to one over the other or will either be suitable thanks dave, http://cgi.ebay.co.uk/AEM-DIGITAL-WIDEBAND-UEGO-CONTROLLER-FREE-SHIP-UK-/270660136399?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f0499edcf#ht_3637wt_834 http://cgi.ebay.co.uk/INNOVATE-DB-BLUE-LED-WIDEBAND-GAUGE-KIT-LC-1-02-SENSOR-/290382630291?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item439c274d93 Quote Link to comment Share on other sites More sharing options...
johnny g Posted January 12, 2011 Share Posted January 12, 2011 (edited) I belive they both use the same sensor, but the AEM doesn't need free-air calibration the way the Innovate does. Am sure more knowledgeable people than me will clear that up! Edited January 12, 2011 by johnny g (see edit history) Quote Link to comment Share on other sites More sharing options...
SupraShaun Posted January 12, 2011 Share Posted January 12, 2011 I asked this a while back - http://www.mkivsupra.net/vbb/showthread.php?204505-Innovate-LC-1-or-AEM-UEGO-AFR-gauge I went for the AEM Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 12, 2011 Share Posted January 12, 2011 Innovate all day long, as the resolution is better, also the data logging software is far better. Quote Link to comment Share on other sites More sharing options...
w41k3r Posted January 12, 2011 Author Share Posted January 12, 2011 seems decisions made thanks for linking that thread typed wideband in and went through a few must have missed yours seems the AEM will be perfect and only £130 cant beat that Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted January 12, 2011 Share Posted January 12, 2011 Ive had the Innovate and the AEM, the AEM is much easier to use. Quote Link to comment Share on other sites More sharing options...
Nic Posted January 12, 2011 Share Posted January 12, 2011 There's not much to chose between them they both do what they're suppose to do, I went with the Innovate, the deciding factor was that it looked similar to the Defi BF gauges I also had fitted. Quote Link to comment Share on other sites More sharing options...
Scott Posted January 12, 2011 Share Posted January 12, 2011 I went with the innovate as it is SOOOOOOOO much nicer Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 12, 2011 Share Posted January 12, 2011 There's not much to chose between them they both do what they're suppose to do, I went with the Innovate, the deciding factor was that it looked similar to the Defi BF gauges I also had fitted. I went with the innovate as it is SOOOOOOOO much nicer True that they both achieve the desired effect, although i still think the Innovate gets better rich resolution, but does nobody use the Innovate software? Does the AEM even come with any data-log software, if so and its anything like the ECU software, then the Innovate stuff is far more intuitive and user friendly. Quote Link to comment Share on other sites More sharing options...
dandan Posted January 12, 2011 Share Posted January 12, 2011 How rich does the Innovate go? The logging would be handy if you didn't have a standalone - I used to used Techedge wideband stuff and always had heaps of stuff being switched in and out of the 0-5v inputs when working on Webers and SU carbs. The logging was a godsend Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 12, 2011 Share Posted January 12, 2011 There's not much to chose between them they both do what they're suppose to do, I went with the Innovate, the deciding factor was that it looked similar to the Defi BF gauges I also had fitted. I went with the innovate as it is SOOOOOOOO much nicer How rich does the Innovate go? The logging would be handy if you didn't have a standalone - I used to used Techedge wideband stuff and always had heaps of stuff being switched in and out of the 0-5v inputs when working on Webers and SU carbs. The logging was a godsend I have heard it will go down to 8.6 AFR i have once logged 9.0 with a an over the top bit of injector DC, as for the software i have done all of my own PFC and EMU tuning using the data-log software, its very easy to mimic maps with it, so it make direct comparisons very easy;) Quote Link to comment Share on other sites More sharing options...
