speedophile Posted January 11, 2011 Share Posted January 11, 2011 (edited) Lads what grade of engine Oil goes in a uk tt supra Edited January 11, 2011 by speedophile (see edit history) Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted January 11, 2011 Share Posted January 11, 2011 A good quality semi synthetic will be fine 10w 40 I think. Quote Link to comment Share on other sites More sharing options...
Nic Posted January 11, 2011 Share Posted January 11, 2011 FAQ Section Quote Link to comment Share on other sites More sharing options...
Kaan W Posted January 3, 2013 Share Posted January 3, 2013 Would this be ok to use? http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_270411_langId_-1_categoryId_165581_zygonArticleNum_570846_zygonGenericCode_000000_zygonId_12887425_zygonManPartNum_H+10W40+PT+SYN Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted January 3, 2013 Share Posted January 3, 2013 Would this be ok to use? http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_270411_langId_-1_categoryId_165581_zygonArticleNum_570846_zygonGenericCode_000000_zygonId_12887425_zygonManPartNum_H+10W40+PT+SYN Did you read the link Nic posted? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 3, 2013 Share Posted January 3, 2013 (edited) Would this be ok to use? http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_270411_langId_-1_categoryId_165581_zygonArticleNum_570846_zygonGenericCode_000000_zygonId_12887425_zygonManPartNum_H+10W40+PT+SYN That should be fine, too much bull where oil is concerned, I've said it before but oil has advanced a long way since the oil for the Supra was speced by Toyota, nearly all modern oils are way better spec than the original, so your average 10W 40 semi synth is fine, why buy an expensive oil that is designed to have a service life of 15K and then change it every 3-5k like a lot of people do. Edited January 3, 2013 by Tricky-Ricky (see edit history) Quote Link to comment Share on other sites More sharing options...
Kaan W Posted January 3, 2013 Share Posted January 3, 2013 Did you read the link Nic posted? Yes. I also posted in that section with no reply and im waiting to go out and need some oil quick! - - - Updated - - - That should be fine. Thanks for your help chap thats what I wanted to know! Quote Link to comment Share on other sites More sharing options...
