Peter P Posted January 11, 2011 Share Posted January 11, 2011 Hi Guys, Rob Mitchell and I were working on my car last night and found the autobox dipstick was cable tied to a pipe!! I'm obviously looking to get it relocated to where it should be and wondered if anyone could do me a picture of where this bolts to on the inlet manifold?? We did find a space for a 10mm nut but the bracket on my dipstick must be bent out of shape as it doesn't line up!! Saying that, when I tried moving it around a bit I noticed it doesn't stay in the hole underneath if I pull it up into position. Hopefully a photo would confirm where it needs to go and also whether mine can be bent into shape or if I need a new one!! All help greatly appreciated chaps! :d Pete Quote Link to comment Share on other sites More sharing options...
Terminator Posted January 12, 2011 Share Posted January 12, 2011 If it is a standard dip stick tube, you should be able to carefully straighten it out a bit to get the proper height. Make sure you clean around the fixing hole in the sump as the chances are it is covered in fine grit down there. Quote Link to comment Share on other sites More sharing options...
Peter P Posted January 12, 2011 Author Share Posted January 12, 2011 If it is a standard dip stick tube, you should be able to carefully straighten it out a bit to get the proper height. Make sure you clean around the fixing hole in the sump as the chances are it is covered in fine grit down there. Will do mate and thanks for the advice. I did try straightening it out but it still looks too low for where I think it is meant to bolt to on the intake manifold. If someone would be kind enough to photo this area for me, I could see where it should go and take it from there? Quote Link to comment Share on other sites More sharing options...
