intercooler water spray any good
mellonman
People get all excited about new stuff when really a stock I/C is probably better than an unducted huge FMIC thing with a cheap core from one of the box shifters. Toyota did a superb install on the standard unit and it's extremely efficient as ALL the air entering the stock bumper aperture has to go through, rather than around the intercooler, and the exit path for the hot air is into a low pressure region in the front wheel arch. Bettering the setup is hard, how many people here have properly ducted FMIC's? Deleting the stock rad duct to fit a front mount I/C also compromises the water rad efficiency. It's easy to spend £700 and make the set up worse that stock.
:yeahthat:
Edited by Kirk (see edit history)
Spot On :thumbs:
okay so they are poo lol
what is the best way to cool inlet temps?
As Chris says, a good quality intercooler with an efficient core, well designed end tanks and properly ducted so the air is forced to go through it, rather than around it. What intercooler do you have fitted?
Water/meth injection.
i have a hks intercooler which will please you nic :D
it has ducting at bottom but not the sides but will soon sort that
Going on from what CW has said, I have been wondering if there would be any mileage in having a second series plumbed side mount cooler fitted to the other side to increase charge cooling and still making use of the orginal side mounting advantages?
You could always go for water injection, and situate two jets at the IC outlet and the throttle body, that way you can benefit from both from a certain amount of charge cooling and also in cylinder cooling to help prevent det, IMO you would get far more than with an IC water spray.
Here's something I wrote on water injection, ages ago, with some tech data from elsewhere at the end. I run WI on every turbo engine I personally run.
I sell water injection, but as you may have noticed, don't push it. It's popularity goes in phases for some reason.
Water injection serves 2 closely related functions on a turbo engined
car. Firstly it cools the charge air temperature by utilising an effect
known as the latent heat of evaporation. This property can be self
demonstrated very easily. If you pour something that evaporates quickly
like petrol on your hand it feels very cold. This is the rapidly
vaporising spirit removing heat from your skin and bloodstream by the
aforementioned process. By spraying a very finely atomised mist of water
into the inlet of a turbo engine when under boost conditions the
evaporation of the water into steam causes a temperature reduction in the air and
fuel intake charge. A cold charge is less likely to be subject to
detonation than a hot charge. A cool charge is also denser, able to
carry more air and fuel mix per unit of volume. These 2 properties of
water injection allow either less chance of detonation at a given boost,
maybe allowing lower octane fuel to be used, or to allow a rise in boost
pressure usage without detonation. These are very desirable goals for
any modifier of a turbo engine, or one using an engine mapped to run
on a higher octane fuel than generally available in the UK. Japanese
import turbo cars for example.
People ask whether squirting water into an engine causes corrosion. In
fact this is not a problem, the combustion temperatures under boost
ensure the water is turned instantly to steam and is ejected out of the
exhaust. The water mist is injected only when high boost is sensed via
a supplied pressure sensor switch. The basic combustion process of
hydrocarbon fuels causes LOTS of water to be generated anyway, which is why cars
not driven on regular long journeys will rust out a mild steel exhaust
system from the INSIDE out. If water is added in the correct volume, via
the supplied, calibrated jets, this is not a problem.
Even when used alongside a larger or more efficient intercooler, or
indeed when an intercooler is used in an application where one was not
present as standard, water injection can and does increase charge cooling
still further. Water can be stored either in the existing windscreen
washer bottle or in a separate, dedicated, container. In cold conditions
it is essential to add an anti freeze additive to the water to stop pump
damage through freezing. Windscreen washer additive serves this purpose
fine and the engine won't mind ingesting this solution at all. Or you
can add neat methanol, which is usually the anti freeze additive in
washer fluid anyway. Using a 50 / 50 percent by volume water / methanol
mix will actually help increase the octane of the intake charge, as an
added benefit. As a yet further advantage the latent heat of evaporation
of methanol is extremely high. A win / win situation. It is not however
obligatory to use methanol as an additive. All components of the water
injection kit that are in contact with the fluid are stainless steel or
able to tolerate water and methanol or screen washer additive without
degradation. A properly set up system does not use a vast amount of
water, in fact a modern car sized screen washer bottle used also for the
water injection reservoir will suffice admirably. A water filter is
included to keep any sludge out of the pump or jet. This should be
checked regularly for contamination and blown out if residue is
apparent within.
A more technical explanation:
Let us take a quick look at ignition. Those who have a Heywood can look it up
- mines on loan so going by memory. The first thing that happens is a plasma
cloud is formed by the arc consisting of super heated electron stripped atoms.
When this cloud "explodes" a ball of high energy particles is shot outward.
The highest energy particles are the hydrogen atoms - and they penetrate the
charge about 5 times as far as the rest of the particles. As they lose energy
and return to normal temps - about 5000 k - they begin to react chemically
with any surrounding fuel and oxygen particles. The effectiveness of spark
ignition is directly related to the availability of free hydrogen. Molecules
containing tightly bound hydrogen such as methanol, nitromethane, and methane
are far more difficult to ignite than those with less bonds.
During combustion - water - H2O ( present and formed ) is extremely active in
the oxidation of the hydrocarbon. The predominate reaction is the following:
OH + H ==> H2O
H2O + O ==> H2O2
H2O2 ==> OH + OH
Loop to top and repeat.
The OH radical is the most effective at stripping hydrogen from the HC
molecule in most ranges of combustion temperature.
Another predominate process is the HOO radical. It is more active at lower
temperatures and is competitive with the H2O2 at higher temps.
OO + H ==> HOO
HOO + H ==> H2O2
H2O2 ==> OH + OH
This mechanism is very active at both stripping hydrogen from the HC and for
getting O2 into usable combustion reactions.
Next consider the combustion of CO. Virtually no C ==> CO2. Its a two step
process. C+O ==> CO. CO virtually drops out of early mid combustion as the O
H reactions are significantly faster and effectively compete for the available
oxygen.
Then consider that pure CO and pure O2 burns very slowly if at all. Virtually
the only mechanism to complete the oxidization ( Glassman - Combustion Third
Edition ) of CO ==> CO2 is the "water method".
CO + OH ==> CO2 + H
H + OH ==> H20
H2O + O ==> H2O2
H2O2 ==> OH + OH
goto to top and repeat.
This simple reaction accounts for 99% + of the conversion of CO to CO2. It is
important in that fully two thirds of the energy of carbon combustion is
released in the CO ==> CO2 process and that this process occurs slow and late
in the combustion of the fuel. Excess water can and does speed this
conversion - by actively entering into the conversion process thru the above
mechanism.
The peak flame temperature is determined by three factors alone - the energy
present and released, the total atomic mass, and the atomic ratio - commonly
called CHON for Carbon, Hydrogen, Oxygen, and Nitrogen. The chemical
reactions in combustion leading to peak temperature are supremely indifferent
to pressure. The temperatures and rates of normal IC combustion are
sufficient to cause most of the fuel and water present to be dissociated and
enter into the flame.
As can be seen above, water is most definitily not only not inert but is a
very active and important player in the combustion of hydrocarbon fuel.
Ricardo and others have documented that under certain conditions ( normally
supercharged ) water can replace fuel up to about 50% and develop the same
power output, or that the power output can be increased by up to 50% addition
of water. This conditions were investigated by NACA and others for piston
aircraft engines. It is important to note that these improvements came at the
upper end of the power range where sufficient fuel and air was available to
have an excess of energy that could not be converted to usable pressure in a
timely manner.
As a side note - Volvo recently released some SAE papers documenting the use
of cooled EGR to both reduce detonation and return to a stoic mixture under
boost in the 15 psi range - while maintaining approximately the same power
output. Notice - they reduced fuel and still get the same power output.
When you consider that EGR consists primarily of nitrogen, CO2, and water ( to
the tune of about two gallons formed from each gallon of water burned ), you
might draw the conclusion that it also was not "inert". They peaked their
tests at about 18% cooled EGR - which would work out to about 36% water
injection and got about the same results under similar conditions that the
early NACA research got.
