Kilps Posted January 11, 2011 Share Posted January 11, 2011 (edited) Whilst scrabbling around under the Supra earlier, I came across this: I'm sure this has a home, which isn't "cable tied to the subframe"! Looks like a sensor to me... what is it and where should it be?? Edit: What's this one too? The one with the blue cable coming from it. Edited March 16, 2013 by Kilps (see edit history) Quote Link to comment Share on other sites More sharing options...
Thorin Posted January 11, 2011 Share Posted January 11, 2011 Easy, it lives in West Sussex. Cat temp sensor? Quote Link to comment Share on other sites More sharing options...
Kilps Posted January 11, 2011 Author Share Posted January 11, 2011 Easy, it lives in West Sussex. Cat temp sensor? Very good! That would explain why it's not attached to anything, seeing as mine is decat. Quote Link to comment Share on other sites More sharing options...
Awisto Posted January 11, 2011 Share Posted January 11, 2011 The tied up one is the cat temp sensor, the other one is an O2 sensor. Quote Link to comment Share on other sites More sharing options...
Kilps Posted January 11, 2011 Author Share Posted January 11, 2011 The tied up one is the cat temp sensor, the other one is an O2 sensor. I thought the second one was an O2 Sensor Thank you again! Quote Link to comment Share on other sites More sharing options...
nevins Posted January 11, 2011 Share Posted January 11, 2011 You have 2 o2 sensors (lambda) and one cat temp fitted on a mkiv fella. Quote Link to comment Share on other sites More sharing options...
Matt H Posted January 11, 2011 Share Posted January 11, 2011 Could it have been removed because of a de-cat? Quote Link to comment Share on other sites More sharing options...
Kilps Posted January 11, 2011 Author Share Posted January 11, 2011 I thought there were two O2 Sensors... the second one is further back than the cats (or where the cats would be) is it not? Quote Link to comment Share on other sites More sharing options...
Kilps Posted January 11, 2011 Author Share Posted January 11, 2011 Could it have been removed because of a de-cat? Very good! That would explain why it's not attached to anything, seeing as mine is decat. That's what I thought Is it likely to be making anything else do funny things because it thinks the cat is stone cold (because it's sensing outside air temperature)? Quote Link to comment Share on other sites More sharing options...
nevins Posted January 11, 2011 Share Posted January 11, 2011 the one will de in the down pipe, before cat and then second will be after cat. Quote Link to comment Share on other sites More sharing options...
Awisto Posted January 11, 2011 Share Posted January 11, 2011 You have 2 o2 sensors (lambda) and one cat temp fitted on a mkiv fella. On a TT? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted January 11, 2011 Share Posted January 11, 2011 Just the one on a TT Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 11, 2011 Share Posted January 11, 2011 UK / US spec TT's have two oxygen sensors, J-Spec TT's have one. N/A's have two. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted January 11, 2011 Share Posted January 11, 2011 Every day is a school day Quote Link to comment Share on other sites More sharing options...
Awisto Posted January 11, 2011 Share Posted January 11, 2011 That's what I was getting at, it's a J-Spec due to the cat temp probe, so only got the one. (this is where I fail as never seen a UK spec with one, but no doubt will be proved wrong ) Quote Link to comment Share on other sites More sharing options...
Kilps Posted January 12, 2011 Author Share Posted January 12, 2011 That's what I thought Is it likely to be making anything else do funny things because it thinks the cat is stone cold (because it's sensing outside air temperature)? The sensor in the cat is a temperature sensor for the cat overheating warning light on the dash... the temp sensor can just be cable tied out of the way, it has no effect on performance. Ah, that answers that then (found in this thread). Quote Link to comment Share on other sites More sharing options...
