TV aerial signal blocked by extension?
tbourner
My mum's got an aerial in the loft, with 2 cables coming out of it, one goes straight through the ceiling to a freeview box, the other cable goes through a connector onto an extension lead into another room and into a freeview TV.
Her next door neighbour on the side where the aerial points has just had a loft conversion, and since then she's not getting enough signal to get a good picture, would it be the new room in the loft blocking the signal?
I've checked the connections as best I can, but as it's both TVs gone I guess it's the aerial. The aerial looks OK and is pointing the right way.
So how do we fix this with no money and no knowledge? Can you get booster amps or anything? Would they work? Do we need to move the aerial over the other side of the loft (there's another aerial over there with a good signal)? Obviously it'd be best to get it on the roof but I don't have the guts to get up and do that! Plus I'm not sure on extending the wiring.
B&Q do connectors and splitter/junction boxes for co-ax cable. Its easy to join up, I managed it, you just gotta make sure all the outer threads are not shorting anywhere.
I suppose its possible if the new interior had lots of dense materials and metal studding for plasterboard it could interrupt the signal. Digital seems to be more corruptable than the old analogue.
I would rejoice in getting any decent sort of signal from a loft aerial. Only 3 of the 4 normal channels are watch able and we lost many Freeview channels when they re tuned and dropped transmitter power. being tight I am awaiting April when the power goes up, otherwise I will have to put an aerial on the chimney stack. Good luck. BTW, did you see the Greenland gods on TV last night, on a documentary about old skill hunters in Greenland? Big brutes! Hope the rescue work is coming along, sterling work!!
No, what was that on? I'm now officially treasurer of Huskies in Need! Gonna be busy.
