stu861 Posted January 9, 2011 Share Posted January 9, 2011 i recently changed my cluster lights in the dash but now the speedo does not work have tried cleaning contacts making sure everything is pushed in properly it all works except speedo not moving at all it was fine before tho! any ideas before i pull my hair out or take a large hammer to it?? Quote Link to comment Share on other sites More sharing options...
Supra Gaz Posted January 9, 2011 Share Posted January 9, 2011 If you knocked the speedo needle it may have got stuck, you may have to remove it and then put it back on carefully. I had that problem when I changed my dials, good luck Quote Link to comment Share on other sites More sharing options...
stu861 Posted January 9, 2011 Author Share Posted January 9, 2011 cheers will try anything doing my head in now mate Quote Link to comment Share on other sites More sharing options...
Smoke_U Posted January 9, 2011 Share Posted January 9, 2011 Mine just stoped wourking same day i had a MOT. But they didn´t notice it.... Its stil not wourking, i havent checkt it yet. Quote Link to comment Share on other sites More sharing options...
stu861 Posted January 9, 2011 Author Share Posted January 9, 2011 found this box behind the dash with yellow red green and blue wires is this the converter??? and have i put them back in the cluster correctly?? Quote Link to comment Share on other sites More sharing options...
Supra Gaz Posted January 9, 2011 Share Posted January 9, 2011 found this box behind the dash with yellow red green and blue wires is this the converter??? and have i put them back in the cluster correctly?? Well that's your convertor alright. I'm sure my wires are different colours unfortunately. If they are wrong the speedo won't do diddly, what make is the convertor? It should be on the small box. Quote Link to comment Share on other sites More sharing options...
Abz Posted January 9, 2011 Share Posted January 9, 2011 Have you connected the dimmer light switch? I believe when I did mine I panicked my wasn't working and then noticed I hadn't connected the dimmer switch on the right hand side of the dash. Quote Link to comment Share on other sites More sharing options...
stu861 Posted January 9, 2011 Author Share Posted January 9, 2011 Well that's your convertor alright. I'm sure my wires are different colours unfortunately. If they are wrong the speedo won't do diddly, what make is the convertor? It should be on the small box. had a look the box has no writing on it at all mate ill just keep swapping the wires and hopefully it should work i guess Quote Link to comment Share on other sites More sharing options...
stu861 Posted January 9, 2011 Author Share Posted January 9, 2011 Have you connected the dimmer light switch? I believe when I did mine I panicked my wasn't working and then noticed I hadn't connected the dimmer switch on the right hand side of the dash. yeah dimmer switch is plugged in mate and working Quote Link to comment Share on other sites More sharing options...
stu861 Posted January 9, 2011 Author Share Posted January 9, 2011 does anyone one now wat wire should connect to which pin?? Quote Link to comment Share on other sites More sharing options...
Homer Posted January 9, 2011 Share Posted January 9, 2011 That's a nasty way to do the conversion, I'd be wanted to rip that all out and do it properly for a start! Can you post a pic of the convertor box as it'll help give an idea what you have there. Most of the cheap ebay ones don't send a corrected output for the variable power steering assistance which can make the car horrible to steer... Quote Link to comment Share on other sites More sharing options...
stu861 Posted January 9, 2011 Author Share Posted January 9, 2011 That's a nasty way to do the conversion, I'd be wanted to rip that all out and do it properly for a start! Can you post a pic of the convertor box as it'll help give an idea what you have there. Most of the cheap ebay ones don't send a corrected output for the variable power steering assistance which can make the car horrible to steer... here mate just a small black box it was all done before i brought the car Quote Link to comment Share on other sites More sharing options...
