Drive shaft removal help
markssupra
Hi all,
Had a search, but cannot find anything about removing the drive shafts from the hubs.
I have dropped the whole subframe and loosened the diff ends of the shafts but the shafts seem stuck inside the hubs. I've sprayed with WD40 and given them a hearty tap, but no movement at all.
Would a large bearing puller work, pulling against the hub? Any ideas gratefully received :)
Thanks
Mark
When you say bit more than a light tap, have you tried an extremely large one or two?
I had the same problem with one of shafts on my car (ex drag use), the only thing that worked was using a 9lb sledge and a good few very heavy hits to get it to move. The nut is not reusable anyway, so best to use that and a strong socket rather than the shaft itself. Otherwise, a press is probably a better way if you have access to one.
On one side even this didn't work since the spline was twisted, so ended up getting a replacement hub and shaft for about £80.
Can you remove the diff without removing the drive shaft from the hub, just from the diff. If you no what i mean? Thanks
Yes you can, just remove the allen key bolts from the drive shaft flange that fits to the diff, the CV joints will compress so just pull it away from the diff to release
I tryed removing the diff off the sub frame yesterday, all was going ok untill one of the drive shafts didnt want the come out of the diff, the other side came out with no probs. i have droped the sub frame off now. whats the safest thing to do without damaging anything?
