markssupra Posted January 7, 2011 Share Posted January 7, 2011 Hi all, Had a search, but cannot find anything about removing the drive shafts from the hubs. I have dropped the whole subframe and loosened the diff ends of the shafts but the shafts seem stuck inside the hubs. I've sprayed with WD40 and given them a hearty tap, but no movement at all. Would a large bearing puller work, pulling against the hub? Any ideas gratefully received Thanks Mark Link to comment Share on other sites More sharing options...
ronttuk Posted January 7, 2011 Share Posted January 7, 2011 its fooked ill give you £50 for it . Lol Link to comment Share on other sites More sharing options...
merckx Posted January 7, 2011 Share Posted January 7, 2011 page 52 http://www.turbosupras.com/pdfs/JZA80%20TSRM/SA.pdf Obtained from http://www.turbosupras.com/pages/pages/technical/jza80/a80tsrm.htm Link to comment Share on other sites More sharing options...
markssupra Posted January 8, 2011 Author Share Posted January 8, 2011 page 52 http://www.turbosupras.com/pdfs/JZA80%20TSRM/SA.pdf Obtained from http://www.turbosupras.com/pages/pages/technical/jza80/a80tsrm.htm Thanks for the link, but I have got the repair manuals and the driveshafts need a bit more than a "light tap" Link to comment Share on other sites More sharing options...
Homer Posted January 8, 2011 Share Posted January 8, 2011 When you say bit more than a light tap, have you tried an extremely large one or two? I had the same problem with one of shafts on my car (ex drag use), the only thing that worked was using a 9lb sledge and a good few very heavy hits to get it to move. The nut is not reusable anyway, so best to use that and a strong socket rather than the shaft itself. Otherwise, a press is probably a better way if you have access to one. On one side even this didn't work since the spline was twisted, so ended up getting a replacement hub and shaft for about £80. Link to comment Share on other sites More sharing options...
markssupra Posted January 8, 2011 Author Share Posted January 8, 2011 Cheers Daryl, I was hoping there may have been a less brutal way, but I will try a larger hammer Link to comment Share on other sites More sharing options...
Oddball87 Posted January 8, 2011 Share Posted January 8, 2011 Can you remove the diff without removing the drive shaft from the hub, just from the diff. If you no what i mean? Thanks Link to comment Share on other sites More sharing options...
Homer Posted January 8, 2011 Share Posted January 8, 2011 Can you remove the diff without removing the drive shaft from the hub, just from the diff. If you no what i mean? Thanks Yes you can, just remove the allen key bolts from the drive shaft flange that fits to the diff, the CV joints will compress so just pull it away from the diff to release Link to comment Share on other sites More sharing options...
Oddball87 Posted January 8, 2011 Share Posted January 8, 2011 Mega thanks Homer. One more thing is the diff ok to paint? If it is high temp paint? Link to comment Share on other sites More sharing options...
Homer Posted January 8, 2011 Share Posted January 8, 2011 It's okay to paint the diff casing, but the back plate should be left unpainted ideally (as Toyota intended). High temp isn't needed so something like a hamerite or any heavy paint should be fine. Link to comment Share on other sites More sharing options...
Oddball87 Posted January 8, 2011 Share Posted January 8, 2011 Ok dude thanks Link to comment Share on other sites More sharing options...
Oddball87 Posted January 10, 2011 Share Posted January 10, 2011 I tryed removing the diff off the sub frame yesterday, all was going ok untill one of the drive shafts didnt want the come out of the diff, the other side came out with no probs. i have droped the sub frame off now. whats the safest thing to do without damaging anything? Link to comment Share on other sites More sharing options...
Oddball87 Posted January 10, 2011 Share Posted January 10, 2011 Sorted Hammers rule Link to comment Share on other sites More sharing options...
