AEM Gaugetech Display for TT/Single
StuartW
NOW sold I have an Gaugetech display, it can replace many dials.
Basically a data streaming digital dash!
I am sure it works with other Makes of ECU's as well.
Has peak warning adjustable warning/red light, Functions that i recall are;
Standard display functions (Just plug it in and these work)
*Rpm
*Batt voltage
*Ignition timing advance/retard
*Inj duty cycle
*Cooling Temp
*Inlet air temp
*Boost/Map
Optional inputs
*EGT
*AFR
*Fuel pressure
*Oil pressure
I need to find the instructions but when plugged in its actually very obvious, it has a menu button, adjustable contrast, adjustable backlight, peak hold features plus many many more.
I plugged it in yesterday and it all lights up as shown.
If anyone can find the manufacturers info on this i would very much appreciate it.
Basically its approx 10"x4"x1" Box that replaces like 20+ dials :)
£200 delivered within mainland UK
Yes the stock one does not have the correct plug (Like a computer plug) i think its called serial "D"
It will probably work with other aftermarket ecu's. It may even work with stock as the Supra does have all of these functions on it anyway, but it would mean cutting and re-wiring it in with a bit of research!
I am pretty sure ANY Piggy back ECU would run it too as they all have the same plug on them.
  • 2 weeks later...
  • 2 weeks later...
  • 2 weeks later...
  • 2 weeks later...
  • 2 weeks later...
  • 2 weeks later...
  • 2 weeks later...
I'm suprised you still have it too, If someone offers me an ecu at a price I can't refuse I'll buy it :/ though an ecu is a long way down my list of things I need, but I am still sorely tempted.
Someone buy it to save me worrying please........
