jayl Posted January 6, 2011 Share Posted January 6, 2011 just a quick question if anyone knows when rolling arches what happens to inner arch do you remove it ? or how does it fix once arches are rolled i feel stupid asking but never seen arches rolled Quote Link to comment Share on other sites More sharing options...
marc_p Posted January 6, 2011 Share Posted January 6, 2011 Rolling arches is just the process of bending back the lip that sticks out in the arch, some people just use a piece of wood and a rubber mallet to do it, but getting it done professionally will mean there is less chance of cracking the paint. Quote Link to comment Share on other sites More sharing options...
marc_p Posted January 6, 2011 Share Posted January 6, 2011 Didn't you have flared arches put on yours? If you did any decent body shop will remove the bottom of the standard arch otherwise it renders the arches useless, so you should have no need to roll them. Quote Link to comment Share on other sites More sharing options...
KamaSupra Posted January 6, 2011 Share Posted January 6, 2011 I've always felt too embarrassed to ask the question myself, so thanks for the simple explanation Quote Link to comment Share on other sites More sharing options...
baldy Posted January 6, 2011 Share Posted January 6, 2011 Even if a proper arch roller is used the paint will crack. Unless you only need a few mm of clearance then you might be lucky,but ill be very surprised if it doesn't Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted January 6, 2011 Share Posted January 6, 2011 Even if a proper arch roller is used the paint will crack. Unless you only need a few mm of clearance then you might be lucky,but ill be very surprised if it doesn't +1 big possibility the paint will crack, actually it will. Quote Link to comment Share on other sites More sharing options...
marc_p Posted January 6, 2011 Share Posted January 6, 2011 +1 big possibility the paint will crack, actually it will. Not always, depends how far back they are rolled, I had the arches rolled on my old Supe, as I only needed a few mm more clearance they weren't rolled flush but to about a 45 degree angle and the paint wasn't cracked(IIRC it was something to do with heating and softening the paint beforehand). Quote Link to comment Share on other sites More sharing options...
jayl Posted January 6, 2011 Author Share Posted January 6, 2011 the arches are rolled back on mine as i have 19s on my car but the inner plastic arches are not bolted on now to the top of arches so the hang a little low and sometimes scrap or catch when turning hard lock Quote Link to comment Share on other sites More sharing options...
