Guest carmsbody Posted January 6, 2011 Share Posted January 6, 2011 (edited) does anyone have the spec sheet for these camshafts. i have tried searching on here and google, and cant find all the details i am after. or if someone can provide a link with the details i am after. the JUN website dosnt list the information i am after either. and also does the 2jz head need to be modified to accept a 10.8mm lift cam shaft, i cant find a definitive answer to that either. -------------------------------------------------------------------------------------- JUN 272 HIGH LIFT CAMSHAFT (ALL INFO CONFIRMED BY JUN CONSULTANT) ADVERTISED DURATION: 272 DEGREES DURATION @ .050":?? LIFT: 10.8MM LOBE SEPERATION: 110 DEGREE BUCKETS: SHIMLESS REQUIRED RETAINERS: EITHER JUN RETAINERS OR MACHINE BOTTOM OF STOCK ONES TO CLEAR VALVE STEM SEAL AT FULL LIFT. MACHINE TO CLEAR LOBE ROTATION: YES TAPPET CLEARANCE: INTAKE O.2MM EXHAUST 0.3MM Edited January 12, 2011 by carmsbody (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest carmsbody Posted January 12, 2011 Share Posted January 12, 2011 anyone?? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 12, 2011 Share Posted January 12, 2011 (edited) It says: "MACHINE TO CLEAR LOBE ROTATION: YES" So the head needs machining to give the cam lobes more clearance. Fairly easy on a universal mill. Plus you need to modify the top spring retainers or buy JUN ones. Here's how I did my Skyline head, the blue ring shows the cut outs. Edited January 12, 2011 by Chris Wilson (see edit history) Quote Link to comment Share on other sites More sharing options...
