fitting oem bumper help
liam1
Have you got the threaded bits that come with an OEM bumper Liam. It's like a long thin curved bar with a threaded bolt at 90 degrees either end. If so then it's an easy job mate. If not I'd personally buy a couple from Toyota there not expensive. Fetch it over if you want I don't mind fitting it for ya.
think ive got that john will def take you up on help fitting it mate cheers.
I have a different number for the left side 52536-14030 from that linked thread.
If your fitting stock from veilside it could be missing quite a few bits, it may not have the front crash bar either.
See the expanded diagram. Do you have the bumper already ? If not try and get the rest of the bits at the same times such as the polystyrene moulding etc.
