peter richards Posted January 4, 2011 Share Posted January 4, 2011 is there any way to tell if the clutch is on its way ? its not slipping but biting point is quite high . thanks peter Quote Link to comment Share on other sites More sharing options...
nevins Posted January 5, 2011 Share Posted January 5, 2011 Just had to do one on sams car mate. High bite point and it was starting to jump out of gear where it was not engaging fully. They have a hydraulic clutch on them. Sam's is a mk1 on a 98 with the 1.8 zetec in it, same as the escort really. If its the mk2 focus that means indicators in the headlights it will have a dual mass flywheel and they are a nightmare and a fortune to buy the clutch kit. Quote Link to comment Share on other sites More sharing options...
Havard Posted January 5, 2011 Share Posted January 5, 2011 Can we change the thread title as I have an urge to grab hold of one..!! H. Quote Link to comment Share on other sites More sharing options...
peter richards Posted January 5, 2011 Author Share Posted January 5, 2011 same car nev s plate 1.8 lx, how much did it cost you mate ?if you dont mind me asking Quote Link to comment Share on other sites More sharing options...
snake Posted January 5, 2011 Share Posted January 5, 2011 put the hand brake on stick it in third gear try and pull away if it stalls its ok for now. Quote Link to comment Share on other sites More sharing options...
peter richards Posted January 5, 2011 Author Share Posted January 5, 2011 thanks ill try it Quote Link to comment Share on other sites More sharing options...
Graham S Posted January 5, 2011 Share Posted January 5, 2011 Gonna sound weird here but check your brake fluid level... It's really common for the hydraulics in the clutch pedal to fail.. Stick your head under the dash and look at the clutch pedal right up at the top if its damp in any way thats your problem! Done bloody hundreds of them... Easy-ish to replace, and think no more than £100 if I rememeber correctly. Quote Link to comment Share on other sites More sharing options...
peter richards Posted January 5, 2011 Author Share Posted January 5, 2011 ok tried the earlier suggestion steady revs and it stalled, will check the level tomorrow. thanks for the replies Quote Link to comment Share on other sites More sharing options...
nevins Posted January 5, 2011 Share Posted January 5, 2011 As above if it stalls its good for a while, I got a full clutch kit for £145, which included the hydraulic thrust bearing thingy majiggy lol. Simple to fit aswell mate. Quote Link to comment Share on other sites More sharing options...
peter richards Posted January 6, 2011 Author Share Posted January 6, 2011 ok mate thanks , i ll see how much i can get a set for here , fitting thats a different matter lol Quote Link to comment Share on other sites More sharing options...
snake Posted January 6, 2011 Share Posted January 6, 2011 The clutch on my old fiesta has been slipping for months if you drive it carefully it will last ages.Some of the clutch kits come with the slave cylinder ,my fiesta kit will be about £125 and the same for fitting. Quote Link to comment Share on other sites More sharing options...
peter richards Posted January 6, 2011 Author Share Posted January 6, 2011 ok thanks i can get the lot for £120, but as said fitting i doubt i could do it myself , just worried atm if it goes because of mike being so ill. appreciate the replies guys Quote Link to comment Share on other sites More sharing options...
