sound deadening and front speaker
ccwade
changed out the stock front triangular mount speakers and replaced with rectangular mount holes. rotate the speaker into a position where one of the mount attach holes line up with the plastic tuned box and use dry wall screws in the other 2 mount holes. you will not have enough room to use the 4th hole.
purchased sound deadening material off ebay, ZillaMat mat'l is approx. .070" thick.
after applying to the door skin and door card area, this stuff makes a major improvement on noise reduction. added weight was less than 5lb's.
i did remove the flimsy plastic mosture barrier, as you can see zillamat has an aluminum moisture barrier on one side. just finished the aft portion of the supra this evening, improved the sound even more. total weight gain due to zillamate is approx. 22lb's. will post some of the pictures in a bit.
