fittings for wastegate question
Stephen G
I want to know what fittings and hose size to order to use for the actuator hoses on a greddy type r wastegate?
Think the thread size on the 2 ports is 1/8 NPT
dependant on your boost control soleniod port size and also boost reference port size use the same hose tail fitting size on the wastegate.
If using silicone hose, buy a good quality hose, use metal securing clips, and heat protect the hose with sleaving.
You can use AN fittings instead of hose tail fittings, and use a 1/8 NPT to 3AN fitting, and run 3AN braided hosing instead of Silicone, this would be the preffered method.
thanks hodge i just found that.
by the way where did you order the fittings?
Stephen you can get them from any good Hydraulics supplier, theres a few down your way- AA Hydraulics, Proturn, Northern Hydraulics
They use JIC as a standard, which is the same as AN, so your looking JIC 3 to 1/8 NTP adapters, they also could make the lines up for ya too
