jon_dragon Posted January 1, 2011 Share Posted January 1, 2011 I found this and wondered what peoples opinions are. http://www.ab88.co.uk/mobile_product_info.php?pName=ab88-autobahn-88-exhaust-manifold-header-toyota-supra-na-jza80-non-turbo Can't find a decent manifold anywhere and mines cracked. I'm even thinking of getting a replacement stock item jus to cure the cra k but a performance one would be better. Quote Link to comment Share on other sites More sharing options...
Aero-M Posted January 1, 2011 Share Posted January 1, 2011 Paul from Whifbitz should have his one available soon, will no doubt be very good quality with some performance gains. Quote Link to comment Share on other sites More sharing options...
nevins Posted January 1, 2011 Share Posted January 1, 2011 Had one on mine, was good enough, but known of a few people to order them and they have been pathetic. Its a risk to take when buying one. Iirc they are all imported from china, where as if you get one off paul you will get a lot better service. Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted January 1, 2011 Share Posted January 1, 2011 i have one on mine and it just needed the holes reemed out a bit. Quote Link to comment Share on other sites More sharing options...
Neil-NA Posted January 2, 2011 Share Posted January 2, 2011 I have one on mine and it need quite a bit to make it fit, all runners were chopped and rewelded, a lot of the holes had to be machines away and I needed 2 gaskets and new o2 sensors, its not pretty but it is the single best thing to do on an NA. Best thing to do is wait for Pauls as you know it will be a quality product that fits perfectly. Quote Link to comment Share on other sites More sharing options...
neo2810 Posted January 2, 2011 Share Posted January 2, 2011 I found this and wondered what peoples opinions are. http://www.ab88.co.uk/mobile_product_info.php?pName=ab88-autobahn-88-exhaust-manifold-header-toyota-supra-na-jza80-non-turbo Can't find a decent manifold anywhere and mines cracked. I'm even thinking of getting a replacement stock item jus to cure the cra k but a performance one would be better. Where in the country are u? (on tapatalk right now) Quote Link to comment Share on other sites More sharing options...
Nic Posted January 2, 2011 Share Posted January 2, 2011 (edited) As has already been said, how well the manifold mates to the head can be an issue, ie. holes not lining up and flanges not square. Check that it will fit a RHD Supra, some manifolds are designed to fit a LHD US Supra and foul the steering column when fitted on a RHD Supra. Check that the bosses for the oxygen sensors are the 2 bolt type - to fit stock O2 sensors - not the screw in type. Edited January 2, 2011 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted January 2, 2011 Share Posted January 2, 2011 You can have the one of mine when I get my turbo lump fitted this year Quote Link to comment Share on other sites More sharing options...
jon_dragon Posted January 4, 2011 Author Share Posted January 4, 2011 cheers guys, looks like Ill get Pauls. A mate of mine has a 350z with american manifolds and he cant steer at high speeds! Also, he's completely lost the distinctive v6 burble. Does that happen with these manafolds too? Quote Link to comment Share on other sites More sharing options...
Neil-NA Posted January 4, 2011 Share Posted January 4, 2011 Mime has qone quite raspy around 3-4k, flat out it sounds like a race car though, i'm hoping pauls will retain the 2jz note. Quote Link to comment Share on other sites More sharing options...
