Guest Joshua Posted December 31, 2010 Share Posted December 31, 2010 Titan Motorsports installed an Aeromotions R2 Dynamic Wing for me. It has a 65 inch Carbon Fiber wing blade and aircraft aluminum uprights with 14 degrees of wing angle adjustment. The total weight of the wing, uprights and actuator control module with servos is about ~17 lbs! The wing is really cool, it has an actuator mounted inside the trunk, Titan came up with a really slick lightweight mount (see pic below). There is a computer that controls the wing angle to deliver the right down force for each type of track section. There is a cornering setting, brake setting (max down force) and straight away setting (0 degree wing angle). I was really fortunate that Greg Mark, one of the Co-Founders of Aeromotions was going to PRI in Orlando and asked if my car was at Titan…and if it was he would take time away from the conference and tune the wing for max down force which would be used the braking setting and then we could set the cornering setting from that. For other cars like the GTR and Porsches, they have a plug-and-play tunes, but for the Supra, there wasn’t one…well until now. There is a point where the wing will stall and no longer produce down force, so having him figure out that point will really help make using this setup much easier and less trial and error during testing. Here is a short video of the wing on my car and how the max down force was determined: Quote Link to comment Share on other sites More sharing options...
Guest Joshua Posted December 31, 2010 Share Posted December 31, 2010 Some pics: Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted December 31, 2010 Share Posted December 31, 2010 That looks very interesting. Is it wind-tunnel tested? Quote Link to comment Share on other sites More sharing options...
Bailey. Posted December 31, 2010 Share Posted December 31, 2010 (edited) Great looking car,loving the lower front splitter idea!! Any more spec?? Edited December 31, 2010 by Bailey. (see edit history) Quote Link to comment Share on other sites More sharing options...
JamieP Posted December 31, 2010 Share Posted December 31, 2010 Nice looking car, i take it you race it? any videos? Quote Link to comment Share on other sites More sharing options...
Guest Joshua Posted December 31, 2010 Share Posted December 31, 2010 That looks very interesting. Is it wind-tunnel tested? Yes, Aeromotions developed the wing at MIT and used a wind tunnel Quote Link to comment Share on other sites More sharing options...
Guest Joshua Posted December 31, 2010 Share Posted December 31, 2010 Nice looking car, i take it you race it? any videos? The car is being set up and developed for TimeAttack... Here are a few videos: Quote Link to comment Share on other sites More sharing options...
Kirk Posted December 31, 2010 Share Posted December 31, 2010 http://www.mkivsupra.net/vbb/showthread.php?236102-Variable-aero-wing. Quote Link to comment Share on other sites More sharing options...
Guest PaulT Posted January 1, 2011 Share Posted January 1, 2011 I could really use one of these, but then again looking at the price How much downforce does it produce at maximum? Paul. Quote Link to comment Share on other sites More sharing options...
