info on power steering pump
Parry_10
Guest suprabass
The pumps are both the same, Ive looked into it before and used both on my Track car only thing that is needed/ different is the fitting on the top that take the feed in from the powersteering bottle, as the NA pumps bottle is bolted to the top of it.
Guest suprabass
You need part numbers:
44337-24020 which is the union your powersteering pipe goes on to. (44337 on the diagram)
90301-11010 which is the o ring for this union
90119-08035 which is the bolt to hold it on (but the NA bolt that bolts the bottle to the pump is the same)
all toyota parts
http://www.internetwork.org.uk/part_num/Power_chassis/images/4502.gif
Edited by suprabass (see edit history)
