dude Posted December 31, 2010 Share Posted December 31, 2010 I played a 1080dp disc on a 1080dp tv and the little box at the top said it was playing in 780dp, is this because the HDMI cable is too low a quality or do I need to go into the blueray player and alter the settings ????????? Quote Link to comment Share on other sites More sharing options...
MrRalphMan Posted December 31, 2010 Share Posted December 31, 2010 Did it say 720p? As you either get 1080(p or i) and 720(P or i). Most BluRay players will have an option to select the output, 90% just use a best available it gets from the TV. I'd do the following first - Check the settings in the BR Player, to ensure that you are not forcing it to 720p If that doesn't work, let us know the make/model of the TV and BR Player. Have you any disks that play at 1080p? and because I'm nosey, what film is it? Paul. Quote Link to comment Share on other sites More sharing options...
monsween Posted December 31, 2010 Share Posted December 31, 2010 Yea its more than likely the BR player/PS3 that isn't running it at full 1080p Quote Link to comment Share on other sites More sharing options...
dude Posted December 31, 2010 Author Share Posted December 31, 2010 Thanks guys, the film was Avatar and Max Payne and the player was a Phillips BDP3000, the TV was my new Haier,http://cgi.ebay.co.uk/Haier-LET40T3-40-LED-FULL-HD-100Hz-TV-Freeview-/110627134094?pt=UK_AudioTVElectronics_Video_Televisions&hash=item19c1e41a8e Quote Link to comment Share on other sites More sharing options...
tbourner Posted December 31, 2010 Share Posted December 31, 2010 1 Press the home button. 2 Select [settings], then press OK. 3 Select [Video Setup], then press the right arrow button. 4 Select 'HDMI Video', then press OK. 5 Select 'Auto', then press OK. • To return to the previous menu, press BACK. • To exit the menu, press the home button. Quote Link to comment Share on other sites More sharing options...
tbourner Posted December 31, 2010 Share Posted December 31, 2010 Ooh, actually, from here: http://download.p4c.philips.com/files/b/bdp3000_05/bdp3000_05_dfu_eng.pdf You can just press the 'HDMI' button (top right of your remote) and it changes HDMI resolution output. Quote Link to comment Share on other sites More sharing options...
dude Posted December 31, 2010 Author Share Posted December 31, 2010 Thanks guys, ill go try the sony in the camper. Quote Link to comment Share on other sites More sharing options...
Ric Posted December 31, 2010 Share Posted December 31, 2010 If that doesent still work Have a look at the bluray box rear Some titles only come in 720p, just because its a bluray doesent mean its automatically 1080p Its whatever the title is recorded in, however you would have thought avatar was 1080p Quote Link to comment Share on other sites More sharing options...
dude Posted December 31, 2010 Author Share Posted December 31, 2010 Thanks guys the phillips was set to 720 the Sony seems to play in 1080 just fine. What type of HDMI lead should I be using, does it actually make any difference at all ??????? The satellite going on the camper is HD as well so I need 2 cables. Quote Link to comment Share on other sites More sharing options...
AndyT Posted December 31, 2010 Share Posted December 31, 2010 Thanks guys the phillips was set to 720 the Sony seems to play in 1080 just fine. What type of HDMI lead should I be using, does it actually make any difference at all ??????? The satellite going on the camper is HD as well so I need 2 cables. Dug this out of AVForums for you Dude. Basically over the lengths you require it doesn't matter what you buy it seems. http://www.avforums.com/forums/2808049-post29.html Seems I may have overspent by about 150 quid. Quote Link to comment Share on other sites More sharing options...
dude Posted December 31, 2010 Author Share Posted December 31, 2010 Thanks dude ASDA for me tomorrow then. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted December 31, 2010 Share Posted December 31, 2010 Thanks guys the phillips was set to 720 the Sony seems to play in 1080 just fine. What type of HDMI lead should I be using, does it actually make any difference at all ??????? The satellite going on the camper is HD as well so I need 2 cables. Using high priced HDMI leads is a waste of money, digital signals don't depend on transmission material's to gain/loses quality unlike analog, so you won't see any difference between a £5 and a £150 cable, other than your bank balance;) Quote Link to comment Share on other sites More sharing options...
JustGav Posted January 1, 2011 Share Posted January 1, 2011 Using high priced HDMI leads is a waste of money, digital signals don't depend on transmission material's to gain/loses quality unlike analog, so you won't see any difference between a £5 and a £150 cable, other than your bank balance;) To a certain length.... Cheapy ones are good for up to around 3m...any longer then sometimes a slightly better lead does help (shielding and such), but the super expensive ones? snakeoil Quote Link to comment Share on other sites More sharing options...
