Dim Sum Posted December 30, 2010 Share Posted December 30, 2010 As mentioned, i have a a set a coilovers which have the grove on the coilover so you can adjust the heigh i assume. If the platform is lowered, does that mean the car will be lowered or raised? Quote Link to comment Share on other sites More sharing options...
mark newman Posted December 30, 2010 Share Posted December 30, 2010 what do you mean about the platform. what is a platform on a coilover. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted December 30, 2010 Share Posted December 30, 2010 Depends on the coilover, some have spring preload height adjustment, where you compress the springs to adjust the height, others have true height adjustment where the shock body screws into a casing on the lower mount, not affecting the spring. Post a pic so we can determine what you have. Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted December 30, 2010 Author Share Posted December 30, 2010 http://www.motoiq.com/magazine_articles/articletype/articleview/articleid/1376/pageid/1628/dai-yoshiharas-two-week-wonder-gt-channels-time-attack-350z.aspx the purple bit at the bottow end of the spring Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted December 30, 2010 Author Share Posted December 30, 2010 Depends on the coilover, some have spring preload height adjustment, where you compress the springs to adjust the height, others have true height adjustment where the shock body screws into a casing on the lower mount, not affecting the spring. Post a pic so we can determine what you have. Mine is the compressed one. Quote Link to comment Share on other sites More sharing options...
mark newman Posted December 30, 2010 Share Posted December 30, 2010 ok let the platform down and the body will come down Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted December 30, 2010 Author Share Posted December 30, 2010 ok let the platform down and the body will come down so if the platform is lowered it should increase the height? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted December 30, 2010 Share Posted December 30, 2010 Lower the collar to lower the ride height, and vica versa Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted December 30, 2010 Share Posted December 30, 2010 so if the platform is lowered it should increase the height? No raise it to raise the height. Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted December 30, 2010 Author Share Posted December 30, 2010 No raise it to raise the height. Thank you:) Sorry to be asking such a noobie question, i'm no mechanic just want to be sure before i carry it out. I had the Supra for seven months and seven months of fun and pain. I had it since stock and i'm hoping after the TT conversion and bodykit i will post a more recent picture of my pride and joy. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted December 30, 2010 Share Posted December 30, 2010 No probs, always better to ask than carry on and cock it up. Its a pai in the arse setting up ride heights, you need to measure each corner to make sure everything is even, which involves jack car up, adjust, lower car, measure, jack up, adjust lower, measure. Repeat ad nausium. Its best to get your geometry checked when youve finished adjusting. Quote Link to comment Share on other sites More sharing options...
Scott Posted December 30, 2010 Share Posted December 30, 2010 No probs, always better to ask than carry on and cock it up. Its a pai in the arse setting up ride heights, you need to measure each corner to make sure everything is even, which involves jack car up, adjust, lower car, measure, jack up, adjust lower, measure. Repeat ad nausium. Its best to get your geometry checked when youve finished adjusting. Don't forget the waiting a day for it to settle too Quote Link to comment Share on other sites More sharing options...
