Guest jimbobjim Posted December 30, 2010 Share Posted December 30, 2010 first of all im new to this forum so hello to everyone im in need of some help! i've got a non turbo manual supra, the engine warning light comes on if i go over 2500 rpm (stays on until i stop the engine.this does not happen if u just rev the engine above 2500rpm only happens while driving, [sHOCK][/sHOCK] if anybody can help me and give me some ideas on what this could be i would be so thankfull!! i love my car and really hope there is nothing major wrong with it [sAD][/sAD] Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted December 31, 2010 Share Posted December 31, 2010 Perform a diagnostic test mate. http://www.mkivsupra.net/vbb/showthread.php?35920-How-To-Check-the-diagnostics-codes Theres the link on how to do it! Quote Link to comment Share on other sites More sharing options...
Morpheus Posted December 31, 2010 Share Posted December 31, 2010 Hi and welcome! I do hope it's nothing serious as well and I'm sure you'll get to the bottom of it and please don't take this the wrong way but before a Moderator says it, (although I think they've kinda given up now by the looks of it ), you might want to run diagnostics on your keyboard while you're at it, as the shift keys seem faulty. Would be good to Capitalise on the opportunity. Quote Link to comment Share on other sites More sharing options...
Guest jimbobjim Posted December 31, 2010 Share Posted December 31, 2010 hi, ive followed the procedure to check for engine codes, the problem im getting now is when i bridge te1 and e1, then turb the ignition on- the mil light does no flash at all? anyone know why it wouldnt flash at all? Quote Link to comment Share on other sites More sharing options...
jevansio Posted December 31, 2010 Share Posted December 31, 2010 What are you using to bridge? You sure you are getting a good connection & are bridging the correct terminals? Quote Link to comment Share on other sites More sharing options...
Guest jimbobjim Posted December 31, 2010 Share Posted December 31, 2010 hi there, im definately getting a good connection have tried everything!! it says in the guide, "If the MIL does not lightup, proceed to troubleshooting of the telltale light RH (See page BE-61" problem is i cant see that page lol Quote Link to comment Share on other sites More sharing options...
Guest jimbobjim Posted December 31, 2010 Share Posted December 31, 2010 anyone else had this problem or know what it could be? as i cant see page 61!! Quote Link to comment Share on other sites More sharing options...
Guest jimbobjim Posted December 31, 2010 Share Posted December 31, 2010 i think i have found the problem! i have managed to download the engine reapir manual for the supra and found page "BE-61" it says that the orange warning light should come on when the ignition is turned on and then go off when the engine is started, when i put my ignition on the orange warning light does not come on at all, it only comes on when driving above a certain rev range(then stays on untill the car is switched off) the manual says that the problem could be with the speedometer- my speedometer has stopped working so this hopefully is the problem!! just thought i'd post that encase anyone else gets the same problem Quote Link to comment Share on other sites More sharing options...
kaahari Posted January 1, 2011 Share Posted January 1, 2011 When you switch ignition normally on, does your check enginel,oil press, oil level lights lid? Do you mean triangle on rpm meter or check engine on right side cluster meaning "orange warning light" ? i`be had two supras with loose connection on that right side warning cluster, hard to see malfunction codes if the light wont work And nice to get these to work, oil pressure and oil level exspecially... If your speedo wont work, atleast there is a code for it... you can see the code from check engine light Quote Link to comment Share on other sites More sharing options...
Terminator Posted January 1, 2011 Share Posted January 1, 2011 Hi and welcome! I do hope it's nothing serious as well and I'm sure you'll get to the bottom of it and please don't take this the wrong way but before a Moderator says it, (although I think they've kinda given up now by the looks of it ), you might want to run diagnostics on your keyboard while you're at it, as the shift keys seem faulty. Would be good to Capitalise on the opportunity. I think that went right over his head. Yet more text speak, and poor punctuation. Someone who can't be bothered. Quote Link to comment Share on other sites More sharing options...
Morpheus Posted January 1, 2011 Share Posted January 1, 2011 I think that went right over his head. Yet more text speak, and poor punctuation. Someone who can't be bothered. Whooosh! Quote Link to comment Share on other sites More sharing options...
Guest jimbobjim Posted January 1, 2011 Share Posted January 1, 2011 "I think that went right over his head. Yet more text speak, and poor punctuation. Someone who can't be bothered." terminator, what are you trying to tell me?? Quote Link to comment Share on other sites More sharing options...
Guest jimbobjim Posted January 1, 2011 Share Posted January 1, 2011 poor punctuation?? its a forum not an english exam u pillock Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted January 2, 2011 Share Posted January 2, 2011 Woohaa there newbie, people are trying to help you, I suggest you wind your neck in on the abuse. To answer your question before you either get yourself banned, or this thread gets deleted. Your first problem is dry solder joints on the light display on the top right section of the dash, it's quite a common problem. Remove the top section of the dash cluster, 4 or 5 screws I think, unplug the multiplugs on either side. Then use a soldering iron to re-seat the solder joins on the small circuit boards. When plugged back in, you'll hopefully see that they now light up when the ignition is turned on. Now re-run the diagnostics and check for codes. Quote Link to comment Share on other sites More sharing options...
Morpheus Posted January 2, 2011 Share Posted January 2, 2011 Is that all it was? Sold that one now anyway. Will inform buyer. Cheers for that! As for this being an exam, I have to carry a box of latex gloves around, the amount of times I've been fingered for being out of order! I'm still learning that sometimes less is more, except sleep, of course. Night night! Quote Link to comment Share on other sites More sharing options...
Terminator Posted January 2, 2011 Share Posted January 2, 2011 poor punctuation?? its a forum not an english exam u pillock Nice chap deserves all the help he can get. His abilities don't get better in his PM's "prick i cant be bothered?? unlike u ive got a life, i havent got 15 thousand posts on some stupid forum!! i only came on here to get some help and now ive sorted it i couldnt care less and wont be back on here again! i bet your some fat old bald git thats got no real mates so they have to talk to people on forums!! " Quote Link to comment Share on other sites More sharing options...
jevansio Posted January 2, 2011 Share Posted January 2, 2011 i bet your some fat old bald git thats got no real mates so they have to talk to people on forums!! " So you know him Phil? Quote Link to comment Share on other sites More sharing options...
supraturbochris Posted January 2, 2011 Share Posted January 2, 2011 phil dont rise too it. I think a ??? Quote Link to comment Share on other sites More sharing options...
3LL Posted January 2, 2011 Share Posted January 2, 2011 Without wanting to risk a ban for such language.. the guy is clearly a C0CK! anyhoo.. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted January 2, 2011 Share Posted January 2, 2011 This forum's going down hill etc etc Quote Link to comment Share on other sites More sharing options...
Branners Posted January 2, 2011 Share Posted January 2, 2011 poor punctuation?? its a forum not an english exam u pillock We are asking you nicely to stop with the txt spk. It really is not that hard to type in full sentences with punctuation and if you wish to post on the forum we ask that you do that. Quote Link to comment Share on other sites More sharing options...
Guest jimbobjim Posted January 3, 2011 Share Posted January 3, 2011 this forum is full of knobs, i ask for a little bit of help and then people are telling me i cant be bothered just because of the way im writing!! and lets be honest if you ban me i can just make up a new username anyway!! 3LL i'd love you to say that to my face you muppet, i'll remember what ur supra looks like and hope i see it around! branners, if someone had asked me nicely to begin with i would have listened but thats all i get is, "he cant be bothered" the forum police lol Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted January 3, 2011 Share Posted January 3, 2011 Youre a real nice piece of work aint you Quote Link to comment Share on other sites More sharing options...
Guest jimbobjim Posted January 3, 2011 Share Posted January 3, 2011 and how the hell am i speking in text???? just because i havent put a capital letter at the start of every sentence!! unbelievable great forum fair play!! Quote Link to comment Share on other sites More sharing options...
Guest jimbobjim Posted January 3, 2011 Share Posted January 3, 2011 its not aint??? cant you speak english!! Quote Link to comment Share on other sites More sharing options...
