black_widow87 Posted December 29, 2010 Share Posted December 29, 2010 Hi guys, im looking at buying rota gtr's in 17". I understand the PCD is 114.3, but unsure what offset i need. Currently looking at 17/9J/ET25, any chance that these would fit? Thanks in advance Jake Link to comment Share on other sites More sharing options...
JamieP Posted December 29, 2010 Share Posted December 29, 2010 http://www.mkivsupra.net/vbb/showthread.php?220233-Finally-got-rims!-went-for-Rota-Grids-ET25-white-in-the-end Link to comment Share on other sites More sharing options...
Nic Posted December 29, 2010 Share Posted December 29, 2010 The Supra usually has a staggered width front & rear, below are the sizes and offsets for the stock wheels. Front - 17 x 8.0 +50 Rear - 17 x 9.5 +50 If you input the stock size/offset into this OFFSET CALCULATOR and then the size/offset of the wheels you are looking at it will tell you how they compare when fitted. Personally I would go for a staggered width front and rear. Also what brakes do you have fitted? If you have the larger brakes you will need to make sure the wheels you go for will clear them. Link to comment Share on other sites More sharing options...
