Chris_k Posted December 29, 2010 Share Posted December 29, 2010 Hi guys, Just went to start my car this morning and there was an awful squeel, bang. Oil light came on so i shut the car off straight away. Pouring out smoke from the bonnet, smelling awful. Had a quick look and i think that the cambelt has snapped which is really annoying as i was planing on changing it in the new year. Is there anyone local to me that could take a quick look at the car and confirm the problem, there is defently a belt problem and a pully has come off. Just so pissed off right now. If someone is abvailible could they give me a quick call or text on 07815029749 or post back on here would be extremely grateful. Cheers Quote Link to comment Share on other sites More sharing options...
Brazil Posted December 29, 2010 Share Posted December 29, 2010 Bad luck dude, How many miles does your car have? Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted December 29, 2010 Share Posted December 29, 2010 (edited) your crank pulley has come off, quite a common problem on the supe. The problem lies with what it smashes into while still spinning at 1000rpm. It's right in front of the oil pump, so it may have damaged that. If I was closer, I'd come round and look to say exactly whats gone, but I'm a bit of a trek away. I'm sure someone more local to you will be able to help. BTW, replacing the crank pulley is not the end of the world. Your car will be fine. Edited December 29, 2010 by pistonbroke (see edit history) Quote Link to comment Share on other sites More sharing options...
The Raven Posted December 29, 2010 Share Posted December 29, 2010 your crank pulley has come off, quite a common problem on the supe. The problem lies with what it smashes into while still spinning at 1000rpm. It's right in front of the oil pump, so it may have damaged that. If I was closer, I'd come round and look to say exactly whats gone, but I'm a bit of a trek away. I'm sure someone more local to you will be able to help. BTW, replacing the crank pulley is not the end of the world. Your car will be fine. Saved me posting. I concur. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted December 29, 2010 Share Posted December 29, 2010 Get some pics of the engine bay mate, particularly down the front where the crank pulley is Quote Link to comment Share on other sites More sharing options...
Scooter Posted December 29, 2010 Share Posted December 29, 2010 Further to the above if you can get hold of a allen key and remove the green spark plug cover then that will uncover the cam pulleys and expose the top of the cam belt.........so you can check if that is still intact (its normally fine). The aux belt at the front is the one that will probably be toast and that may be responsible for the bad smell............ Quote Link to comment Share on other sites More sharing options...
Lude Posted December 29, 2010 Share Posted December 29, 2010 if the crank pulley gets damaged wont it upset the timinmg belt somehow? Quote Link to comment Share on other sites More sharing options...
JamieP Posted December 29, 2010 Share Posted December 29, 2010 Get some pictures up, as above, sounds like crank pulley fail, as you mention smoke it may have taken out the oil pump, not going to be a cheap fix if it has im afraid to say. Quote Link to comment Share on other sites More sharing options...
Terminator Posted December 29, 2010 Share Posted December 29, 2010 if the crank pulley gets damaged wont it upset the timing belt somehow? The crank pulley only drives the serpentine belt. The cam belt is driven from a toothed drive behind the pulley, belt hidden behind covers. It is always pot luck when the crank pulley goes, sounds like the OP has had one of the worst outcomes. With older cars where the rubber damper in the pulley will have age hardened, it is certainly worth doing the Tippex test on a regular basis. Quote Link to comment Share on other sites More sharing options...
Chris_k Posted December 29, 2010 Author Share Posted December 29, 2010 Thanks for your replies, its dark now but i will go and take a few snaps where i can. The AA took a quick look and said it was the drive belt, and confirmed it was the crank pully. Quote Link to comment Share on other sites More sharing options...
pezzler Posted December 29, 2010 Share Posted December 29, 2010 Feel bad for you Chris, more than likely wont be a cheap repair if the oil pump is completely fecked. Just to get the ball rolling with the repair calculations, Whifbitz are the cheapest place about for OEM crank pulleys - about £230. Dont buy 2nd hand Quote Link to comment Share on other sites More sharing options...
Chris_k Posted December 29, 2010 Author Share Posted December 29, 2010 Some quick pictures: Quote Link to comment Share on other sites More sharing options...
JamieP Posted December 29, 2010 Share Posted December 29, 2010 Yup, failed crank pulley, i cant see any oil so with a bit of luck the smoke was from the belt shredding, you may get away with just a new belt and pulley. Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted December 29, 2010 Share Posted December 29, 2010 ouch! proper fooked. as above smoke could be from the belt so fingers crossed Quote Link to comment Share on other sites More sharing options...
mark newman Posted December 29, 2010 Share Posted December 29, 2010 I have a very good 2nd hand one you can have ,can of mine before i went single . easy job to do your self, you need a belt. but you will have to pick up from reading. Quote Link to comment Share on other sites More sharing options...
L18msy Posted December 29, 2010 Share Posted December 29, 2010 Do these things go at a certain mileage or age or is it just your luck? What is the best way of checking that all is ok? Quote Link to comment Share on other sites More sharing options...
Josh Posted December 29, 2010 Share Posted December 29, 2010 Do these things go at a certain mileage or age or is it just your luck? What is the best way of checking that all is ok? Tipex test. I think draw a line all the way from top to bottom and see if the line breaks i.e. it's slipping. Quote Link to comment Share on other sites More sharing options...
stevie_b Posted December 29, 2010 Share Posted December 29, 2010 Do these things go at a certain mileage or age or is it just your luck? What is the best way of checking that all is ok? I think the crank pulley is an item that Toyota recommends is changed at a particular interval, although I don't know what that interval is. You can test it by using the Tippex test (search on here for details). Quote Link to comment Share on other sites More sharing options...
L18msy Posted December 29, 2010 Share Posted December 29, 2010 Thanks, Tippex will be blagged from the estimators office tomorrow! Quote Link to comment Share on other sites More sharing options...
Chris_k Posted December 29, 2010 Author Share Posted December 29, 2010 (edited) Thanks for all your help guys, really appriciate it. Also does anyone know anyone that would come out to fix this? Cheers Edited December 29, 2010 by Chris_k (see edit history) Quote Link to comment Share on other sites More sharing options...
