Lexus v300 vertex edition twin turbo vvti tiptronic
steviek
Hi i have for sale my Lexus . It is tested till next april and taxed till end of december can re tax, It is a 1997 newer shape in silver.
Has the original chrome alloys and very good tyres.Has had one previous owner and everything works as it should.
Has covered 269,000 kms although you would not tell to drive it.
Turbos work properly and the engine is very quiet, with no smoke or rattles of any kind.
gearbox is also excellent with all functions working correctly even the steering wheel controls both up and down the gearbox.
i will try to get photos on here alternatively i can email them.
Bodywork is also very good with only a slight scrape on passenger door which was caught on a gate post, will polish out.
Looking for offers around £2500 for a very comfortable fast car.
OK now I'm confused. That's not his eBay listing then? Why's he only had it a month?
I don't know, just using the logic that the advert has the name Lee and on here it's a guy called Steve selling it :)
Also had a bit of an odd MOT history
Approximate date of first use:30/06/1998
Date of test: 30/03/2006
Certificate issue refused (Fail)
Odometer reading:265,812 Kilometres
Test number:194889886058
Test station name:CAMPBELLS
Test station number:6772BG
Test station telephone number:01642478720
Test class:IV
Reason(s) for refusal to issue Certificate
Offside Front Windscreen has damage to an area in excess of a 10mm circle within zone 'A' (8.3.1a)
Offside Rear parking brake recording little or no effort (3.7.A.7a)
Rear Steering system has excessive free play detected at the steering wheel (steering rack fitted) (2.2.A.1b)
Nearside Rear Upper Suspension arm has excessive play in a ball joint (2.4.G.3)
No Advisory Notice issued
Date of test:15/05/2006 Certificate issued (Pass)
Odometer reading:265,948 Miles
Test number:682525436133
Test class:IVTest expiry date:14/05/2007
Date of test:12/03/2008Certificate issue refused (Fail)
Odometer reading:268,247 Miles
Test number:480342678079
Test station name:ECONOFIX
Test station number:29632
Test station telephone number:01642677931
Test class:IV
Offside Rear fog lamp missing (1.3.1a)
Rear fog lamp tell tale not working (1.3.1b)
Front Registration plate has a feature which changes the appearance or legibility of the characters (6.3.4c)
Rear Registration plate has a feature which changes the appearance or legibility of the characters (6.3.4c)
Nearside Windscreen wiper does not clear the windscreen effectively (8.2.2)
Offside Windscreen wiper does not clear the windscreen effectively (8.2.2)
Nearside Rear Brake disc(s) excessively pitted (3.5.1h)
Offside Rear Brake disc(s) excessively pitted (3.5.1h)
Nearside Front brake binding (3.7.A.2a)
Nearside Rear Rear brake binding (3.7.A.5a)
Rear brake application uneven (3.7.A.5c)
Brake pedal creeps down while the pedal is held under pressure (3.3.B.1a)
Offside Rear Suspension arm has excessive play in a ball joint (2.4.G.3)
Exhaust emissions carbon monoxide content after 2nd fast idle excessive (7.3.D.2b)
Parking brake efficiency below requirements (3.7.A.10) **DANGEROUS**
Front brakes imbalanced (3.7.A.2d) **DANGEROUS**
Change of details
Make/Model:LEXUS / GS300 recorded at time of test on 12/03/2008
Date of test:11/07/2008 Certificate issue refused (Fail)
Odometer reading:268,294 Kilometres
Test number:670523898105
Test station name:PLATINUM MOTORS
Test station number:7036AJ
Test station telephone number:01642713800
Test class:IV
Rear fog lamp switch missing (1.3.1a)
Front Registration plate character(s) likely to be misread (6.3.4b)
Rear Registration plate character(s) likely to be misread (6.3.4b)
Offside Rear brake binding (3.7.A.5a)
Exhaust emissions carbon monoxide content at idle excessive (7.3.D.2c)
Offside Rear Upper Suspension arm has excessive play in a ball joint (2.4.G.3)
Date of test:22/01/2009 Certificate issue refused (Fail)
Odometer reading:41,162 Miles
Test number:514162829068
Test station name:RIVERSIDE MOT SERVICE CENTRE
Test station number:V102108
Test station telephone number:01642219961
Test class:IV
Nearside Stop lamp not working (1.2.1b)
Nearside Rear Tyre worn close to the legal limit (4.1.E.1)
Date of test:22/01/2009Certificate issued (Pass)
Test number:880632129018
Test class:IV
Test expiry date:21/01/2010Advisory Notice issued
Date of test:09/04/2010Certificate issue refused (Fail)
Odometer reading:268,331 Kilometres
Test number:494389190081
Test station name:EAST CLEVELAND ENGINEERING LTD
Test station number:V102156
Test station telephone number:01287 204067
Test class:IVReason(s) for refusal to issue Certificate
Front both Windscreen wiper does not clear the windscreen effectively (8.2.2)
Both Registration plate character(s) incorrectly spaced (6.3.4a)
Both Registration plate with character(s) which are not the correct stroke width (6.3.4a)
Brake pedal has insufficient reserve movement (3.3.A.5)
Date of test:23/04/2010Certificate issued (Pass)
Test number:243463410135
Test class:IVTest expiry date:22/04/2011
Taken from here http://clubaristo.net/forums/showthread.php?t=25559&page=2
But still a good buy if the car is OK.
Shame my circumstances suddenly changed, otherwise I'd would have loved to been looking at it :(
Nice one on the sale, didn't think it'd hang around long.
