wesmi01 Posted January 3, 2003 Share Posted January 3, 2003 A few questions lads!!!! I have a green LED on the dash that is after market and sits just above the steering coloum but below the glass off the dials. Squashed in there as it were. Can't for the life of me figure out what it dose. No pattern to it!!!! Also when I brake, My right rear light cluster lights up both brake lights and also the right indicator light. Any ideas??? Also Chris if your out there, where's my restictor ring?????????????? Quote Link to comment Share on other sites More sharing options...
Graham Rudd Posted January 3, 2003 Share Posted January 3, 2003 Ahh, yep, I never could find a nice place to took that out of the way. Its the RL diagnostic LED, probably set up as a gear shift indicator at the minute. Quote Link to comment Share on other sites More sharing options...
Graham Rudd Posted January 3, 2003 Share Posted January 3, 2003 As for the light cluster/indicator thing. No clue really, could the cluster's connector pins have corroded and turned to mush or something? Might be worth having a look. Quote Link to comment Share on other sites More sharing options...
wesmi01 Posted January 3, 2003 Author Share Posted January 3, 2003 Cheers Graham, Dosent seem to come on just high in the revs. Also comes on low down as well. Could it light when dectecting slip? Quote Link to comment Share on other sites More sharing options...
Gordon F Posted January 3, 2003 Share Posted January 3, 2003 Originally posted by wesmi01 Also when I brake, My right rear light cluster lights up both brake lights and also the right indicator light. Any ideas??? Normally a sign of a bad earth on the light unit. (at least it is on Fords!!) As Graham says, check all the connectors, but also have a good look at the earths. Quote Link to comment Share on other sites More sharing options...
