Dim Sum Posted December 23, 2010 Share Posted December 23, 2010 (edited) How to remove stock steering wheel? Also the airbag. Edited December 23, 2010 by Dim Sum added picture (see edit history) Quote Link to comment Share on other sites More sharing options...
hackin_n_bashin Posted December 23, 2010 Share Posted December 23, 2010 There are 2 covers, one at 3 o'clock, one at 9, prise these out carefully, that will give you access to the 2 torx bolts behind them. Undo those, they are retained in the wheel, and pull the airbag out gently. There is a yellow cable on the rear of the airbag, unclip, and undo this and the airbag is out. Behind the airbag is a 17mm (I think, could be 19mm) nut. Give this a sharp yank anticlockwise and undo it until it's loose but still on the threads. A few short taps on the back of the wheel should free it off it's splines. Leaving the nut on will stop it hitting you in the face when it free's up Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted December 23, 2010 Author Share Posted December 23, 2010 There are 2 covers, one at 3 o'clock, one at 9, prise these out carefully, that will give you access to the 2 torx bolts behind them. Undo those, they are retained in the wheel, and pull the airbag out gently. There is a yellow cable on the rear of the airbag, unclip, and undo this and the airbag is out. Behind the airbag is a 17mm (I think, could be 19mm) nut. Give this a sharp yank anticlockwise and undo it until it's loose but still on the threads. A few short taps on the back of the wheel should free it off it's splines. Leaving the nut on will stop it hitting you in the face when it free's up:thumbs: Thank you, i'll give it ago now. Quote Link to comment Share on other sites More sharing options...
hackin_n_bashin Posted December 23, 2010 Share Posted December 23, 2010 oh, and I disconnect my battery. Don't want a facefull of airbag!! Quote Link to comment Share on other sites More sharing options...
Ricky49 Posted December 23, 2010 Share Posted December 23, 2010 A big hammer Quote Link to comment Share on other sites More sharing options...
Tyson Posted December 23, 2010 Share Posted December 23, 2010 I replace mine with an up to date alternative. I don't know if it works yet but the guy I bought it off says that I will never need another one. That's got to be good right? http://www.epicfail.net/wp-content/gallery/cache/384__h=x_airbag_epicfail.jpg Quote Link to comment Share on other sites More sharing options...
Lude Posted December 23, 2010 Share Posted December 23, 2010 ^^^ lol Quote Link to comment Share on other sites More sharing options...
Graham S Posted December 23, 2010 Share Posted December 23, 2010 Yeah, whatever you do, dosconnect your battery first. They say to leave it off for about half an hour before you remove the bag but never had any problems going straight in and removing it. Quote Link to comment Share on other sites More sharing options...
