Parry_10 Posted December 22, 2010 Share Posted December 22, 2010 Hi guys, can an aristo engine loom just be extended to work to a supra tt? And can a uk tt loom be used on a j spec tt with a uk ecu and uk injectors and resistor pack and maf sensor? Cheers Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 22, 2010 Share Posted December 22, 2010 I suppose if you were handy, patient and have good circuit diagram reading skills you could buy the loom connectors for a Supra ECU and cut the Aristo ones off, if they are different, and put the Supra ones on. Sounds like a PITA to me, but if Aristo looms are commonplace it's a way forward. My new Skyline is going to have a home made loom, I ma now fairly confident wiring aftermarket ecus to RB26 engines, and I only need to use the Nissan coilpack and TB connectors, all the other sensors are Bosch or Marelli with freely available terminal kits. Quote Link to comment Share on other sites More sharing options...
Parry_10 Posted December 22, 2010 Author Share Posted December 22, 2010 Thanks for your response, its just hard to know what to do as people say different things like earlier i was told the aristo loom is the same and just needs extending Quote Link to comment Share on other sites More sharing options...
