jspec & uk diffs
eyefi
The Export spec was more powerful, which allows you to lengthen the gearing without losing acceleration. Longer gearing reduces emmissions cause you don't stress the engine as much at a given speed. MPG is also improved.
Cuth if you mean how can a j-spec hit 162 and a uk go only to 155, you've mis-understood. The uk is limited to 155 - take the limiter off and it is geared to 204mph.
The j-spec comes limited to 112mph take the limiter off and it will be geared to 196mph.
  • Replies 86
Posted Images
Originally posted by cuth
Alex and eyefi - Thanks for clearing that up.
However it is a bit disappointing to hear that
I'm never going to hit 200 in my J-Spec....boohoo!
It will, once you raise the rev limit when you've modified your block and head to handle more power and revs, oh and fitted an aftermarket ECU! :D
try the M25 - you'll have pictures oif you speed at certain
ponts around, then you can post these on the Board
to prove you made it to 200,
plus you'll have nothing better to do being banned for 5 years
Plus if your going against a UK spec - you'd "leave it standing"
for the first few GATSO's :flame Dev :flame Dev
Originally posted by Steve W
[there you go....showin' off the UK-jobbie AGAIN !:mad: ]
Sorry.....errrrm.....English instead then for Steve......or the same as Steve's but mean't for somewhere else......or........errrrm...........errrrm.......I dunno!
Tell you what mate, the cars red. Yours has to be better now. :baa:
Alex,
Just to throw a spanner in the works.
I have never known a UK car to be limited - I know of 3 other UK supras that have sailed passed the limit. I myself to 172 leptons and others to over 180.
Whats the crack with this then?
Gaz.
Matt,
as far as I know it's a SPEED thingy....
Pete's 'box-of-tricks' takes the SPEED signal and does several
things to it...
Converts from km-miles - by altering number of pulses (5/8ths
or 8/5ths ? ?).
( you can then send either of the 2 signals to the speedo or the
odometer - your choice !)
AND it grabs the SAME signal - which also gets sent to the ECU -
and 'CAPS' it to ~100/110 mph...THAT IS limits the pulses to an
amount = that speed.
The ECU then thinks your 'sticking' to that speed when in fact . . .
. . . . . .! ! ! !:flame Dev
Basically you feed ONE wire IN to Pete's box and have 3 wires out
AS IS.
RE-RATIO-ED.
CAPPED.
Mine WAS limited to ~ 120 (?), snipped the wire to the ECU, fed it
the 'CAPPED' wire = WAHOOOOOOO !:cool:
[i [b]THINK[/b] !:conf: ]
FatS.
Now THAT I don't know........MATTSIE !( :p )
(don't get involved with UK rubbish........ggrrr.....rant....dribble.....)
You may be right, UK and Jap limiters may work different ways,
'cos,
WE can't knock the limiter out by pullin' the TRAC fuse !
(can't seem to knock the TRAC out by pullin' it either !)
GOD, this thread is far too tecnybubble for the likes of me......
derr...emmm....oh yer....FatS.
You can't turn the TRAC off in the Jap car...?? The button is there though ain't it. Now I'm confused!?!?!?:looney:
My TRAC button seems to work, tested it just the other day by doing somewhat of a spirited start from a set of light with it turned off. Tyres smoked more than a Rasta sat on the beach in Jamaica!:D
Needless to say, won't be testing it again......once is enough.
NAH, if I turn it off it STILL seems to interrupt me' 'fun' - not that
it's easy to spin the wheels on the auto' anyway ! !
AND, with it ON, it seems to have a delay of ~ 1 second...?
ie. when I had my 'likkle' accident, the wheels spun, it stepped out
hard one way, I 'sort of' corrected, then the TRAC cut in and
made it pendulum back the other way ! ! ?
I NOW don't spin the wheels in the wet AT ALL.....
I drive like a SOPPY-SOUTHERNER until the sun shines again :p
Originally posted by gazwalker
Alex,
Gaz.
From my experience at 10 of the Best, I think I can say the following is a pretty accurate account of what happens (UK spec auto);
With the TRAC fuse in, you keep accelerating until the ECU thinks that the combination of revs and gear are giving more than a TRUE 155mph, then it activates the TRAC butterfly (bad boy!). At TOTB, I got up to about 182 on the clock, but the best official timing was 157 or 158.
I think one of the other Supras at the Nissan 200 TOTB2 can also substantiate this.
You should be able to Steve... I can. If yours doesn't work then unplug the butterfly... Can't fail! :)
Gaz, All the reviews I've read say the UK's limited to 155... Even my original Top Gear video review says that.
