Winter Works To Do List
2soops
Hi all, i was bored yesterday and thought i'd write down all the things i want to get done over the winter whilst the sup's sort of off the road. I suprised myself by the length of the list;
1) Fit the HSD's i just bought
2) Change the fuel filter
3) Up rate to Walboro Fuel Pump
4) Change one foam bolster in the Recaros
5) Paint in rear tailgate recess where Mr T didnt bother
6) Fit front UK spec calipers i bought in February
7) Full geometry allignment
8) Bleed clutch fluid
9) Full Service
10) Revert back to stock Air Filter
11) Change IC pipes
12) Change Spigot rings on wheels
13) Put blanking cover in dash where A Spoiler switch was
14) Put switch on ariel to stop being up when CD player on
15) Tippex test crank damper
16) Check timing belt as slipped a tooth once before
17) Locate whining noise, possibly wheel bearing or ball joint affecting geometry
18) Change coil pack clips
19) Go BPU
Im sure theres probably other jobs but i think that'll do for know
Anyone else got a big to do list?[sHOCK][/sHOCK]
