n/a ecu remap...
Scutch0
ok, cool cheers for the info guys, probably go for something like a emanage blue if i do it, unless anyone knows of someone able to remap her?
it was pretty reasonable on fuel, but recently its dropped off... high teens very low 20's when crusing...
i am actaully in a postion to sell but im having second thoughts...
i cleaned the o2 sensors shortly after i got her, but ive never replaced them, what kinda cost am i looking at for a new set?
If they're duff cleaning them won't make any difference, they are £100+ each x 2 on an NA. There's a possible group buy for new sensors HERE
They're not cheap - although a lot cheaper than a piggy back ECU and mapping - if your sensors do need replacing new ones should make a big difference to fuel economy, you should also feel a noticeable improvement in response.
Unfortunately being an older 3lt six pot, its never going to be great on fuel, even remapping is not going to make much difference as N/As spend most of there time in closed loop, as said new lambda sensors should help, you can find cheaper, or universal type at better prices, if you hunt around.
