Guest montzz1 Posted December 13, 2010 Share Posted December 13, 2010 hi guys could really do with a bit of advice here as im a bit stuck and dont wana kill myself so close to chrismas! ive got meself a auto tt but have a problem with blowing cold air in the car all the time , ive read all the threads regarding this i could find and had the front of the car up on ramps today running with rad cap off ow before this i cleared the matrix with hose pipe connected to tap thought id done it as heater was blowing out pretty warm but when i got it off ramps and went 4 a drive went cold again i was wondering as car has such high millage 180000kph and not knowing when water pump was last changed could the water pump not have enough to push water around the matrix ie ; on its way out the car doesnt overheat at all and it does get pushed around the rad ok but this seems more than an air lock or am i wrong Quote Link to comment Share on other sites More sharing options...
Dnk Posted December 13, 2010 Share Posted December 13, 2010 (edited) i doubt if its the water pump, if it was that lame the engine would over heat. 180,000 kms is only 111,000 miles, did you get much gunge out the matrix, i guess you have checked the flaps are working correctly. try bleeding it again as they can be quite stubborn to get all the air out, did you raise the rpm while bleeding it ? the heater air on full hot should also get very hot and not just warm Edited December 13, 2010 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
mellonman Posted December 14, 2010 Share Posted December 14, 2010 check that the control clip has not come off, you can see form undr the dash from passenger foot well, are you loosing coolent at all? Quote Link to comment Share on other sites More sharing options...
Scooter Posted December 14, 2010 Share Posted December 14, 2010 when it's up to temperature carefully check to see if both the in and out matrix hoses are warm/hot....... Quote Link to comment Share on other sites More sharing options...
JS2004 Posted January 21, 2011 Share Posted January 21, 2011 Guys.. might be a daft question.. but when replacing heater matrix how do I stop the airbag coming out of the closet in glorious in your face fashion...? Is it as simple as disconnecting the battery? Quote Link to comment Share on other sites More sharing options...
