uneven rear suspension
Jay_vr6
ok then, I had the car in my garage over the weekend and noticed that the left rear suspension sits higher than the right side rear, about 18mm difference.
I've had a look under the back and nothing seems noticeably bent or out of place. I had the all the bushes checked out in march and all sub frame bolts etc checked an there was no problems there, I've not hit anything since having this checked.
I wonder (hoping) if it could be shock absorber or spring related ? any ideas before i start buying lots of parts i may not need..
I'd take both the rear shocks off and take the springs off and see if ones longer than the other, could also be differant spring weight with one side being higher than the other.
Have you bounce tested it on either side, easy way to check if a dampers blown but should still sit fairly level.
Whats the front like ?
