Jay_vr6 Posted December 13, 2010 Share Posted December 13, 2010 ok then, I had the car in my garage over the weekend and noticed that the left rear suspension sits higher than the right side rear, about 18mm difference. I've had a look under the back and nothing seems noticeably bent or out of place. I had the all the bushes checked out in march and all sub frame bolts etc checked an there was no problems there, I've not hit anything since having this checked. I wonder (hoping) if it could be shock absorber or spring related ? any ideas before i start buying lots of parts i may not need.. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted December 13, 2010 Share Posted December 13, 2010 verry commom on old cars mate. , new springs and dampers usually dose the trick, Quote Link to comment Share on other sites More sharing options...
Dnk Posted December 13, 2010 Share Posted December 13, 2010 I'd take both the rear shocks off and take the springs off and see if ones longer than the other, could also be differant spring weight with one side being higher than the other. Have you bounce tested it on either side, easy way to check if a dampers blown but should still sit fairly level. Whats the front like ? Quote Link to comment Share on other sites More sharing options...
Jay_vr6 Posted December 13, 2010 Author Share Posted December 13, 2010 the front sits fine, guess its going to be a case of whipping them both off and checking Oh and bump tested the rear and it seems fine. Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted December 13, 2010 Share Posted December 13, 2010 Worn shocks and springs mate, I had it on my old supe. I suggest a nice set of adjustable coilovers for xmas Quote Link to comment Share on other sites More sharing options...
