Suprash Posted December 12, 2010 Share Posted December 12, 2010 Right, my gremlin has returned, had this once before, but it seemed to resolve itself, well, until its now come back lol. But basically the car isnt starting again, now when it did it before I checked everything, spark was good, fuel was good, checked all connections on the engine loom, checked all the ECU wiring, it all seemed good, then suddenly one day it started after doing nothing, great I thought, its fixed lol...... Then the other week during the cold I went to run her up to keep out the frost and she started, like last time, run for a minute or two then just cuts out and wont start again. She just continuously turns over ? My mate is saying crank position sensor or cam position sensor ? What does an NA use ? I need to resolve this non-starting issue fairly quickly, Im supposed to be skidding at Mallory on Thursday Quote Link to comment Share on other sites More sharing options...
Suprash Posted December 12, 2010 Author Share Posted December 12, 2010 Anyone, help, please lol, Im no good with these sorts of gremlins Quote Link to comment Share on other sites More sharing options...
Andy Blyth Posted December 12, 2010 Share Posted December 12, 2010 It does sound like a crank or cam sensor issue. On the NA, these are in the distributor. Have you checked for error codes? I would expect errors in the trigger sensors to be detected. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted December 12, 2010 Share Posted December 12, 2010 Try the fuel pump ECU bypass, might help? Quote Link to comment Share on other sites More sharing options...
Suprash Posted December 13, 2010 Author Share Posted December 13, 2010 It does sound like a crank or cam sensor issue. On the NA, these are in the distributor. Have you checked for error codes? I would expect errors in the trigger sensors to be detected. Cant check for error codes, I dont have any dash instrumentation to flash a sequence code through.......plus Im running a Fcon, will that still log errors like the stock ECU ? Try the fuel pump ECU bypass, might help? Im bypassed already, no fuel pump ECU...... Quote Link to comment Share on other sites More sharing options...
Suprash Posted December 13, 2010 Author Share Posted December 13, 2010 So if the NA gets its crank & cam positions through the dizzy, 4 wires so I believe, 1 common ground, 1 crank and 2 cam, is it worth earthing the ground, just to eliminate any earthing issues ? Can this sensor fail ? is it worth getting another sensor to eliminate again ? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted December 13, 2010 Share Posted December 13, 2010 Thing to do is try to start it again, then whip a spark plug out, if its dry youve got a fuel problem, if its wet then its an ignition snag. Thats what Id do, narrows down your options a bit. Quote Link to comment Share on other sites More sharing options...
Suprash Posted December 13, 2010 Author Share Posted December 13, 2010 Thing to do is try to start it again, then whip a spark plug out, if its dry youve got a fuel problem, if its wet then its an ignition snag. Thats what Id do, narrows down your options a bit. They are wet, I know fuel is ok. But yes, its trying to figure out the ignition issue, which is my dilema lol Quote Link to comment Share on other sites More sharing options...
Suprash Posted December 14, 2010 Author Share Posted December 14, 2010 Right, Gav gave me a wiring diagram for the ignition side of things, so I now know that the green wire coming off the dizzy is the earth, so Im going to re-earth that and see what I get Quote Link to comment Share on other sites More sharing options...
Guest ugp Posted December 14, 2010 Share Posted December 14, 2010 Hook the pc upto to the fcon, surely the software for it will display pulses from either sensor? It does on my emanage anyway. Quote Link to comment Share on other sites More sharing options...
Suprash Posted December 14, 2010 Author Share Posted December 14, 2010 Not got any software for it Gav was supposed to be sorting something out for me. Quote Link to comment Share on other sites More sharing options...
