SupraDan24 Posted December 11, 2010 Share Posted December 11, 2010 Hi guys, ive recently removed my Do-Luck spoiler which, sadly, was just bolted on and not sealed in any way. As a result, ive been left with these minging black outlines of where the spoiler used to be. Can anyone suggest a product that would definately remove this (ie someone who has encountered the same problem). Ive tried T-Cutting it and it had no effect at all. Secondly, can anyone tell me what the correct product for sealing the new spoiler is and whether you just simply apply it to the base of the spoiler then clean up the excess? Lastly, this is slightly harder to explain as i forgot to take a photo, once i had the old spoiler off, there were squareish bits of blue plastic pretruding from where the spoiler was, are these anything to do with the stock spoiler and should they be removed when fitting a TRD? I realise these might be basic Q's, but i want to get it right first time, not trial and error. Pic's are below. Cheers guys, Dan ps the TRD looks better on the car than my Photoshop effort lol Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted December 11, 2010 Share Posted December 11, 2010 if its some sort of glue sealent, then use some tar and glue remover and also a rubbing compund like G3 should sort it. Quote Link to comment Share on other sites More sharing options...
pauld36 Posted December 11, 2010 Share Posted December 11, 2010 do not use g3 its a rubbing compound use neat petrol on a soft cloth it will take a little work but its not hard,[keep dabbing in petrol to keep cloth wet ,,good luck Quote Link to comment Share on other sites More sharing options...
SupraDan24 Posted December 11, 2010 Author Share Posted December 11, 2010 Cheers, i'll give the petrol a go then. Quote Link to comment Share on other sites More sharing options...
Scott Posted December 11, 2010 Share Posted December 11, 2010 do not use g3 its a rubbing compound use neat petrol on a soft cloth it will take a little work but its not hard,[keep dabbing in petrol to keep cloth wet ,,good luck To be fair to Jurgen I think he meant to use the G3 once the residue was off to bring the shine of the paint back Tar remover is a good shout, as is petrol. Make sure the car is spotless once you are finished though. Petrol might burn into your paint if it stays there long enough. Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted December 11, 2010 Share Posted December 11, 2010 To be fair to Jurgen I think he meant to use the G3 once the residue was off to bring the shine of the paint back Tar remover is a good shout, as is petrol. Make sure the car is spotless once you are finished though. Petrol might burn into your paint if it stays there long enough. yes thats what i ment use Tar and glue remover once its off use a bit of G3 and polish the boot up.. it should come up a treat.. petrol will probably cost more Quote Link to comment Share on other sites More sharing options...
SupraDan24 Posted December 12, 2010 Author Share Posted December 12, 2010 Cheers guys, I'm going to pick up some G3 tomorrow abs some petrol and give it a go. Fingers crossed it'll come off as I want my car back :-( Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted December 12, 2010 Share Posted December 12, 2010 Use Eucalyptus oil with a cloth or soft brush, removes tar so this should be easy... After that wash it off with normal car wash shampoo, no damage to the paint... Here is a pic of it in action on my rims... http://i155.photobucket.com/albums/s298/Rajeevjagath/DirtyRim1.jpg http://i155.photobucket.com/albums/s298/Rajeevjagath/DirtyRim2.jpg http://i155.photobucket.com/albums/s298/Rajeevjagath/Oilinprogress1.jpg http://i155.photobucket.com/albums/s298/Rajeevjagath/Oilinprogress.jpg http://i155.photobucket.com/albums/s298/Rajeevjagath/FullyCleanedRim.jpg GOod luck! Quote Link to comment Share on other sites More sharing options...
SupraDan24 Posted December 12, 2010 Author Share Posted December 12, 2010 Use Eucalyptus oil with a cloth or soft brush, removes tar so this should be easy... After that wash it off with normal car wash shampoo, no damage to the paint... Here is a pic of it in action on my rims... http://i155.photobucket.com/albums/s298/Rajeevjagath/DirtyRim1.jpg http://i155.photobucket.com/albums/s298/Rajeevjagath/DirtyRim2.jpg http://i155.photobucket.com/albums/s298/Rajeevjagath/Oilinprogress1.jpg http://i155.photobucket.com/albums/s298/Rajeevjagath/Oilinprogress.jpg http://i155.photobucket.com/albums/s298/Rajeevjagath/FullyCleanedRim.jpg GOod luck! Tried the oil mate, didnt do a thing. Going to try the petrol tomorrow. Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted December 12, 2010 Share Posted December 12, 2010 bit of thinners would remove that, then g3 compound. Quote Link to comment Share on other sites More sharing options...
SupraDan24 Posted December 12, 2010 Author Share Posted December 12, 2010 bit of thinners would remove that, then g3 compound. I've got white spirit, would that do the same job? I was going to use it before, but i was worried about it removing the paint around the area. Quote Link to comment Share on other sites More sharing options...
SupraDan24 Posted December 15, 2010 Author Share Posted December 15, 2010 Update: I tried Petrol, thiners, Eucalyptus oil lol. Nothing even looked like it was going to move it, so i decided to bite the bullet and use some 1200 wet and dry. I managed to virtually all of it off within about 30 mins of graft, i used some G3 conpound on it afterwards to bring back the shine then waxed it to protect it. Here's a before and after shot, i'm alot happier now. Quote Link to comment Share on other sites More sharing options...
SupraMan Mk4 Posted December 15, 2010 Share Posted December 15, 2010 Good Work Dan. Quote Link to comment Share on other sites More sharing options...
Guest blueangel Posted December 15, 2010 Share Posted December 15, 2010 well done dude Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted December 15, 2010 Share Posted December 15, 2010 good finish you done there! Quote Link to comment Share on other sites More sharing options...
SupraDan24 Posted December 15, 2010 Author Share Posted December 15, 2010 Cheers guys, i'm really happy with it. Just going to re-spray my TRD then fit it. Does anyone know what those yellow plastic bits are for? I'm guessing they're something to do with the original spoiler? They're going to have to come out either way as they're fouling on the TRD. Quote Link to comment Share on other sites More sharing options...
Josh Posted December 15, 2010 Share Posted December 15, 2010 Nice work Wouldn't know anything was ever there now. Quote Link to comment Share on other sites More sharing options...
evinX Posted December 18, 2010 Share Posted December 18, 2010 the stock spoiler has 2 bolts and a locater in the centre, which that yellow thing is for. When fitting the new spoiler, get some decent silicone, i used windscreen sealer, apply it from the top of the boot around the holes and the bottom from the inside, tighten the bolts and that will prevent water from getting in:) good job dude! Quote Link to comment Share on other sites More sharing options...
wallis Posted December 18, 2010 Share Posted December 18, 2010 good job dan, when u fitting the new spoiler mate ? Quote Link to comment Share on other sites More sharing options...
Supra Gaz Posted December 18, 2010 Share Posted December 18, 2010 Does that mean your selling tour D-L spoiler? Drop me a pm if you are, I will have it off you! Quote Link to comment Share on other sites More sharing options...
