kwalker705 Posted December 10, 2010 Share Posted December 10, 2010 Got a question for the guy's running single turbo's How did you guys run your turbo oil return lines....I specifically want to know what you did in regards to the housing where the oil returns connect to the sump. There are two return line connections on it but on a single turbo there is only one return line. Did you guy's just blank up the unused return ? Or did you fabricate/buy a new housing with one connection specifically for a single turbo ? Any advice would be great as I'm not 100% sure on what the best way forward is. Quote Link to comment Share on other sites More sharing options...
TLicense Posted December 10, 2010 Share Posted December 10, 2010 A lot of kits come with a suitable return fitting that replaces the twin exit one. Alternatively, if you have know / have access to a machine shop, it's a 10 minute job to make something. Quote Link to comment Share on other sites More sharing options...
