marc_p Posted December 10, 2010 Share Posted December 10, 2010 I have found the wheels I want at long last, they are available in the below specs, but how much wider do you think I'll need to go at the front/rear to fit them in? Or will they fit under a stock body? Rims Size: 19 X 9.5" fronts & 19 X 11" rears Bolt Pattern: 5 X 114.3 Offset: 20 mm fronts & 18 mm rears Cheers Marc Quote Link to comment Share on other sites More sharing options...
DARETT Posted December 10, 2010 Share Posted December 10, 2010 It will be very difficult on a stock body with those offset's at the back. Fronts may work Overfender's or a widebody kit most likely. I run 11" rears on modified stock arches but the offset is pretty high as well.. Are they off a Supra? Quote Link to comment Share on other sites More sharing options...
marc_p Posted December 10, 2010 Author Share Posted December 10, 2010 It will be very difficult on a stock body with those offset's at the back. Fronts may work Overfender's or a widebody kit most likely. I run 11" rears on modified stock arches but the offset is pretty high as well.. Are they off a Supra? Hmm, well I was wanting to get the fibreglass version of JamieP's carbon arches, so this could work well. The wheels are for a 350z. Quote Link to comment Share on other sites More sharing options...
marc_p Posted December 10, 2010 Author Share Posted December 10, 2010 These are them on the 350, not sure how much they differ on offsets between the Supra and the 350. Quote Link to comment Share on other sites More sharing options...
Jamesy Posted December 10, 2010 Share Posted December 10, 2010 A 350z can run bonkers low offset mate. They wont fit stock arches easily. My new wheels just fit on the front with a slightly stretched tyre. My rears stick out a few mm. My sizes are: 18x9.5 et25 18x11 et24 If u go with those Nur arches you'll want even wider than what youve found as those arches give u a lot more room for massive wheels with aggressive offsets Quote Link to comment Share on other sites More sharing options...
Thorin Posted December 10, 2010 Share Posted December 10, 2010 Some people look for wheels they like that will fit their car. Others look for wheels they like and then worry about how they'll make them fit the car later. I don't understand the latter group of people, but they are nice wheels. Quote Link to comment Share on other sites More sharing options...
Jamesy Posted December 10, 2010 Share Posted December 10, 2010 I fall into the latter. If wheels are your 'thing' and wheels Of stock-ish size look lame to some, then the next step is find the ultimate wheels u want and make them fit. Depends how much u love the wheels and how much u dot mind the effort and expense of getting them to fit right Quote Link to comment Share on other sites More sharing options...
marc_p Posted December 10, 2010 Author Share Posted December 10, 2010 A 350z can run bonkers low offset mate. They wont fit stock arches easily. My new wheels just fit on the front with a slightly stretched tyre. My rears stick out a few mm. My sizes are: 18x9.5 et25 18x11 et24 If u go with those Nur arches you'll want even wider than what youve found as those arches give u a lot more room for massive wheels with aggressive offsets Just been looking at the pics in your garage, I might be able to get away with the do luck front wings and rear arches. Quote Link to comment Share on other sites More sharing options...
Nic Posted December 10, 2010 Share Posted December 10, 2010 Similar sort of look to the Weds SA-67R wheels. http://www.weds.co.jp/images/products/wedssport/sa67r_blc.jpg http://www.weds.co.jp/images/products/wedssport/sa67r_car_02.jpg http://www.weds.co.jp/images/products/wedssport/sa67r_car_01.jpg Quote Link to comment Share on other sites More sharing options...
Westy Posted December 10, 2010 Share Posted December 10, 2010 Similar question on fitment...hope you dont mind me hi jacking...but didnt want to start a new thread with the same title: I'm looking to get a set of Work VS-XX in burning black finish (BKB) 18". I have seen this one that states its are WORK VS-XX in Black (BLK) Finish. Sizing on the one in the pic is a 19×9.5 +40 F & 19×11.5 +47 R, with a 265/30/19 F & 315/25/19 R: I'm guessing that the offsets would be the same in an 18" wheel and to run these widths that the stock arches would have to be rolled!? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 10, 2010 Share Posted December 10, 2010 Some people look for wheels they like that will fit their car. Others look for wheels they like and then worry about how they'll make them fit the car later. I don't understand the latter group of people, but they are nice wheels. Me neither, but that's the way things seem to be going. Quote Link to comment Share on other sites More sharing options...
