PC Related.....Second Card Showing Up As Disabled So Can Not Enable ATI crossfire
a98pmalcolm
Ok they used to be crossfired but not anymore. I havent no luck tonight. Im feeling Such a noob with PC's at the moe :(
Ok in device manager it shows there are 2 HD4850 cards, In GPU-Z there is 2 but crossfire is disabled.
In CCC there is no option for enable them.
I think it was the update that made this happen so i reinstalled and still no luck. Both cards work perfectly and are powered up
Here is what it says in CCC information:
Primary Adapter
Graphics Card Manufacturer Powered by ATI
Graphics Chipset ATI Radeon HD 4800 Series
Device ID 9442
Vendor 1002
Subsystem ID E104
Subsystem Vendor ID 174B
Graphics Bus Capability PCI Express 2.0
Maximum Bus Setting PCI Express 2.0 x8
BIOS Version 011.021.000.005
BIOS Part Number 113-BA1E104CSA-QI4
BIOS Date 2009/07/21
Memory Size 1024 MB
Memory Type GDDR3
Core Clock in MHz 625 MHz
Memory Clock in MHz 993 MHz
Total Memory Bandwidth in GByte/s 63.6 GByte/s
Disabled Adapter
Device ID 9442
Vendor 1002
Subsystem ID E810
BIOS Version 011.007.000.000
BIOS Part Number 113-AB50102-X12
BIOS Date 2008/08/11
Memory Size 1024 MB
Memory Type GDDR3
Any help would be great.
Crossfire and SLI only needs one 'clip' attached not two.
Enabling and disabling crossfire is done in CCC. Make sure you are viewing the advanced version. Still no go then get all the drivers and CCC off and reinstall, you may need to wipe the drivers too, and reinstall with the latest or a different driver.
Unlikely but your 'clip' aka bridge could be garffed or worse one of the cards.
Oh, and update the BIOS on the second card to at least match the newer BIOS. :)
Thanks for the reply guys.
Crossfire was enabled before this update i did. So mobo deffo supports the feature.
I was considering updating the drivers but i hear is real risky.
Normally i have the crossfire tab in the CCC advanced but after the update the tab isnt there and there not crossfired no more.
Will look into updating the drivers and as requested a pic:
http://img254.imageshack.us/img254/1958/20101210003.jpg
http://img132.imageshack.us/img132/3360/20101210004.jpg
All sorted now.
Ok what i did was totaly remove anything to do with ATI.
Then tryed to reinstall CCC. After installation i got an error with the ati driver fail.
Low and behold blue screen
Went into device manager and updated both card drivers that way.
Restarted the comp. And the crossfire tab was there and it was enabled, also with the info the 2nd driver is confirmed link not disabled.
Now the drivers are correctly installed lets see if i get blue screens.
Many thanks for the time again guys, this is simple stuff and im finding it all a rite challenge atm.
