urgent help please! look at this photo.
carl0s
http://www2.css-networks.com/belt.jpg
can anybody tell me if the belt is meant to be going round that pulley? Because it's actually in the collar inside of that pulley.
I'm in tescos carpark and my car as started making a loud squeaking noise which Chris Wilson says sounds definately like the belt slipping probably caused by one of the things ceasing. But looking in the bay i can see the belt isn't going round that pulley, although the pulley seems to be too far out anyway.
If anyone could txt-message me or ring me on 07766 087 677 with the answer I'D appreciate that, as I'm in tescos carpark using my mobile phone (9.6kbps GSM) to post this and it's sooooooo slow!
SilverMachine you're a star. Thanks very much for ringing me to let me know and thanks Chris for the diagnosis. I just hope there's a simple reason why that pulley is out of alignment. I've been towed home now and am about to go spannery on it :D
Is this the crank pulley? Its a possiblility that the outside has sheared away from the inside if its like that, Neen reading on here thats it quite a common problem if you have an older car and if the pulley has ever been heated up to undo the crank pulley bolt....remember, its only held together with rubber and some vinegar and brown paper :p
it's looking that way!
can i just glue / loctite the bastard back on?
It feels like a tight press-fit so I should hope it would be okay.
My belt was actually running around the rubber !! the pulley was on it's way to flying off inside the engine bay :o eek. does this thing spin at full engine RPM?
http://www2.css-networks.com/pulley/1.jpg
http://www2.css-networks.com/pulley/2.jpg
http://www2.css-networks.com/pulley/3.jpg
http://www2.css-networks.com/pulley/4.jpg
pulley ordered at a cost of £177 + vat -"a bit of a discount" (probably a measely 10%) so perhaps £160+vat.
My next visit after Tescos was going to be one of my suppliers to buy a network IP Camera for £140 + vat to have a play with. So glad I didn't buy that now!!
That seems to be happening a lot recently - mine went a couple of months ago, and I was quoted around £500 for a new pulley! Got a second-hand one for the kind of price you mentioned here.
Actually, count yourself lucky - when mine went, it took the fan with it too! (see pic)
Chris
I have a used one here ,good nick,£50
canI have your phone number please mate?
just ordered from toyota but they're not placing the order until monday morning.
Has it been removed properly or has heat been used?
please gimme your number or ring me on 07766 087 677!! :D
