davep Posted December 8, 2010 Share Posted December 8, 2010 hi ya just wondering if i buy a Q45 Throttle Body for a nissan skyline what will i need to do to convert it to suit a supra ? thanks Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted December 8, 2010 Share Posted December 8, 2010 Isnt the Q45 from the 300ZX? You need a TPS adaptor and to make 'use' of the larger diameter you would really need to use an enlarged plenum Quote Link to comment Share on other sites More sharing options...
JamieP Posted December 8, 2010 Share Posted December 8, 2010 Greddy intake was built to take a Q45, you also need the TPS kit, part number 13910400. Q45 comes from a Nissan Infiniti. Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted December 8, 2010 Share Posted December 8, 2010 Greddy intake was built to take a Q45, you also need the TPS kit, part number 13910400. cheers jamie, needed that part number Quote Link to comment Share on other sites More sharing options...
JamieP Posted December 8, 2010 Share Posted December 8, 2010 cheers jamie, needed that part number Thats a Greddy part number btw. Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted December 8, 2010 Share Posted December 8, 2010 Thats a Greddy part number btw. yeah cool mate cheers, still available easy though?? Quote Link to comment Share on other sites More sharing options...
davep Posted December 8, 2010 Author Share Posted December 8, 2010 its just on the skyline forum theres 1 for sale so thought i would ask not sure if i should buy it to store for when i change more stuff Quote Link to comment Share on other sites More sharing options...
JamieP Posted December 8, 2010 Share Posted December 8, 2010 yeah cool mate cheers, still available easy though?? Should be, if not any machine shop could make one easy enough, its just a spacer. Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted December 8, 2010 Share Posted December 8, 2010 i think you need a 90mm bore one, am i right in thinking that? or are they 100mm Quote Link to comment Share on other sites More sharing options...
JamieP Posted December 8, 2010 Share Posted December 8, 2010 i think you need a 90mm bore one, am i right in thinking that? or are they 100mm 87mm iirc. Quote Link to comment Share on other sites More sharing options...
davep Posted December 8, 2010 Author Share Posted December 8, 2010 has anyone got any sizes as i can make this no probs thanks jamie for the code Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted December 8, 2010 Share Posted December 8, 2010 has anyone got any sizes as i can make this no probs thanks jamie for the code Make what? Quote Link to comment Share on other sites More sharing options...
JamieP Posted December 8, 2010 Share Posted December 8, 2010 Make what? The TPS kit i guess. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted December 8, 2010 Share Posted December 8, 2010 Greddy intake was built to take a Q45, you also need the TPS kit, part number 13910400. Q45 comes from a Nissan Infiniti. Infiniti is fly by wire jamie, Q45 is from Z32 and Centra, IE earlier models, you wouldn't be able to use the later ones unless you add all the electronics and stepper motors. Quote Link to comment Share on other sites More sharing options...
JamieP Posted December 8, 2010 Share Posted December 8, 2010 Infiniti is fly by wire jamie, Q45 is from Z32 and Centra, IE earlier models, you wouldn't be able to use the later ones unless you add all the electronics and stepper motors. I bought mine being advertised as a Infiniti Q45, maybe some never had dbw? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted December 8, 2010 Share Posted December 8, 2010 Sorry jamie:blush:, was thinking of only later Infiniti, you're right, as the earlier models they called Infiniti in the states where actually based on the JDM Sentra, Cedric, Gloria and Cima, and would of had cable throttle. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 9, 2010 Share Posted December 9, 2010 Do you need, or even want a bigger throttle plate area though? Two cheap boost gauges plumbed just before and just after the throttle plate on a stock set up will easiliy show if there's a meaningful pressure drop across it and it could do with being bigger. Needlessly increasing throttle plate area can give a trigger like low throttle opening response, and the the top third of the throttle travel doing little if anything at all. In conditions of low traction (he says looking out the window....) a linear and stable throttle response is very very desirable. Quote Link to comment Share on other sites More sharing options...
