johnch Posted December 8, 2010 Share Posted December 8, 2010 Hi, Would appreciate if someone with a jz80 that currently has their engine out of the car could measure the distance between the engine mounting holes on the front subframe. Doing a one off swap using a 2jz motor and this would greatly help. Thanks in advance. http://img576.imageshack.us/img576/5739/85124831.jpg Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted December 8, 2010 Share Posted December 8, 2010 The absolute minimum distance between the two mounting holes is 480mm. Each hole is slotted to the tune of 25mm. From what I can gather this means the distance between the engine mount bolts can be between 480mm and nearly 530mm. Quote Link to comment Share on other sites More sharing options...
johnch Posted December 8, 2010 Author Share Posted December 8, 2010 Thanks a lot for that! Seems as though my swap will be relatively easy. Thanks. Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted December 8, 2010 Share Posted December 8, 2010 No problem and best of luck with the project. All I ask in return is plenty of detailed pictures! Quote Link to comment Share on other sites More sharing options...
