a98pmalcolm Posted December 8, 2010 Share Posted December 8, 2010 Hay all. Ok i have a problem. From time to time i get Blue Screens pop up and it restarted the computer. I dont always have enough time to read what the error message is as the comp reststarts. The last time it did with i did see "memory management" but the error messages can be different I have run memory tests and there is no errors. Its recently new 2 2GB sticks of DDR2 Corsair XMS2 1066 Also Corsair ram cooler RAM Fans to keep them cool. Also im on Windows 7 Proffesional 32 BIT Any help would be great. Many thanks The system is overclocked here are some screen shots http://img841.imageshack.us/img841/3152/20101202001c.jpg http://img706.imageshack.us/img706/2977/20101202003.jpg http://img801.imageshack.us/img801/8562/20101202004.jpg Quote Link to comment Share on other sites More sharing options...
creative Posted December 8, 2010 Share Posted December 8, 2010 have a look in the minidump and see if its placed a file in there. If it has, you could send it over and I will have a look at it for you if you wish using windows debug. you could also try bluescreen view and have a look yourself. Quote Link to comment Share on other sites More sharing options...
shima60 Posted December 8, 2010 Share Posted December 8, 2010 I know this sounds stupid but have you tried the dram frequency & voltage etc. I know you have set it up but have you tried just taking it down a notch. Could the Dram not sit at 1066 instead of 1067 or did the motherboard not like that? little things first Quote Link to comment Share on other sites More sharing options...
DamanC Posted December 8, 2010 Share Posted December 8, 2010 The blue screen could be attributed to anything. when you clocked your machine did you give it a run on memtest after and prime 95? how long did you run them for? Has it only started happening since the OC? It maybe something as simple as a program causing it. Get BSV on it and let us know what you find. Quote Link to comment Share on other sites More sharing options...
DamanC Posted December 8, 2010 Share Posted December 8, 2010 I know this sounds stupid but have you tried the dram frequency & voltage etc. I know you have set it up but have you tried just taking it down a notch. Could the Dram not sit at 1066 instead of 1067 or did the motherboard not like that? little things first ASUS boards have ratios therefore you can only select the value that comprehends with the next ratio, rather than your own made up number. Quote Link to comment Share on other sites More sharing options...
TonytotheB Posted December 8, 2010 Share Posted December 8, 2010 BSODs can be caused by anything. Have you installed drivers recently? Give us the full spec including PSU, gcard, HDD, cdroms drives etc Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted December 8, 2010 Author Share Posted December 8, 2010 ok I have down loaded BSV and i can see all the main errors. I dont really know what im looking at with these errors maybe you can have a look and see what you think. I have attached the file Many thanks Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted December 8, 2010 Author Share Posted December 8, 2010 BSODs can be caused by anything. Have you installed drivers recently? Give us the full spec including PSU, gcard, HDD, cdroms drives etc Cant think of any drivers recently. Here is my full spec: CPU: Intel Quod Core Duo 9550 Ram: 4GB 1066 DDR2 Corsair XMS Mobo: Asus P5Q Deluxe Cooler: Corsair H70 CD Rom: TSST Corp DVDRom Sound Card: Creative SB X-fi Graphics Card: x2 of ATI Sapphire HD 4850 PSU: 1000w i-cute Quote Link to comment Share on other sites More sharing options...
creative Posted December 9, 2010 Share Posted December 9, 2010 have you tried taking out each stick of ram? Also try updating the GFX card drivers as these tend to cause a few issues. A quick google of the bug check code on the Ms site should give you the answers. edit... seems you have had a few BSOD's! Quote Link to comment Share on other sites More sharing options...
TonytotheB Posted December 9, 2010 Share Posted December 9, 2010 Cant think of any drivers recently. Here is my full spec: CPU: Intel Quod Core Duo 9550 Ram: 4GB 1066 DDR2 Corsair XMS Mobo: Asus P5Q Deluxe Cooler: Corsair H70 CD Rom: TSST Corp DVDRom Sound Card: Creative SB X-fi Graphics Card: x2 of ATI Sapphire HD 4850 PSU: 1000w i-cute The 1000W PSU seems adequate but have these causes problems before? It doesn't seem like a meanstream brand? I googled and found this link. Not the first place to start anyway Try taking each RAM stick out and memtesting them separately. This should always be the first point of call. Prime95 will do the trick and show errors. It takes time but so to BSODs Is your mobo BIOS up to date? Check on the ASUS website. It allows you to select the mobo and then download the latest drivers http://support.asus.com/download/download.aspx?SLanguage=en-us Soundcards are the next port of call. Is your SC driver up to date? Google that as Creative are not great with compatibility. I have had a few and had problems with some games etc Let us know Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted December 9, 2010 Author Share Posted December 9, 2010 The icute PSU has done me well for a year now. Its a maplins job but im impressed with it so far. Yes the bios is uptodate. I have a feeling it could be sumin to do with sound card drivers. As iv had a pop up before saying sound card driver not installed but it is. I reinstalled anyway. I could leave it one prime 95 while im at work 2moro. So i will do. I have cleared CMOS and running totaly standard settings to check if the possability of my overclock was unstable. Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted December 10, 2010 Author Share Posted December 10, 2010 Update. Reinstalled ATI drivers. But twice i ran a mcafee can and got blue screen so i uninstalled all items of mcafee withe there tool and reinstalled. all seems fine now. mcafee can scan with no crashs. Will keep you all updated on the blue screens. Thanks Paul Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted December 10, 2010 Author Share Posted December 10, 2010 Nope got one again 121010-27721-01.dmp 10/12/2010 02:14:26 UNEXPECTED_KERNEL_MODE_TRAP 0x1000007f 0x00000008 0x8dd39750 0x00000000 0x00000000 dxgkrnl.sys dxgkrnl.sys+1bdb DirectX Graphics Kernel Microsoft® Windows® Operating System Microsoft Corporation 6.1.7600.16432 (win7_gdr.091001-1312) 32-bit C:\Windows\Minidump\121010-27721-01.dmp 4 15 7600 Quote Link to comment Share on other sites More sharing options...
TonytotheB Posted December 10, 2010 Share Posted December 10, 2010 Google the error code... and try saying thanks! http://techrepublic.com.com/5208-11184-0.html?forumID=48&threadID=172533&messageID=1756619&tag=content;leftCol http://techrepublic.com.com/5208-6230-0.html?forumID=89&threadID=162695&messageID=1701753&tag=content;leftCol Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted December 10, 2010 Author Share Posted December 10, 2010 and try saying thanks! I always say thanks bud lol. I appriciate all the help off the members, and even yours I think my blue screens were due to ati drivers not working correctly. Thanks again mate Quote Link to comment Share on other sites More sharing options...
Scott Posted December 10, 2010 Share Posted December 10, 2010 Google the error code... and try saying thanks! http://techrepublic.com.com/5208-11184-0.html?forumID=48&threadID=172533&messageID=1756619&tag=content;leftCol http://techrepublic.com.com/5208-6230-0.html?forumID=89&threadID=162695&messageID=1701753&tag=content;leftCol Thanks is easy. Try rugababybuggybumpers, that's much harder. Quote Link to comment Share on other sites More sharing options...
